Author Topic: Starter bolts  (Read 5525 times)
Offline rickyharp
Starter bolts
« on: May 07, 2012, 07:44:58 am »
I have a 1985 silverado k-10 with a 1980 4 bolt 350 out of a bonaza k-10,my problem is the starter bolts are stripped out .Should I put a heli core in the block or should I drill them out to the next size?The 350 has been bored out .30 over stock and runs alot better than the stock 305 ever did.Please someone help!!!!!
Offline jaredts
Re: Starter bolts
« Reply #1 on: May 07, 2012, 07:57:25 am »
Don't know how bad they are stripped, but I'd try new bolts and running the correct size tap into the block if there's any chance that will work.  Heli-coil would be my next stop.
Offline rickyharp
Re: Starter bolts
« Reply #2 on: May 07, 2012, 08:24:22 am »
The bolts are pretty bad,a good tap did not work.I can start it up and hear the bolt are loose,so tighten them up, they are good.drive to work,go to leave need to tighten them again.I have a heli-coil set but never installed one before.
Re: Starter bolts
« Reply #3 on: May 07, 2012, 09:56:41 am »
is it the bolts or the holes? parts stores sell starter bolts
Re: Starter bolts
« Reply #4 on: May 07, 2012, 09:58:12 am »
also there are some that have problems with the holes breaking.  i would only mess with them if it was the last thing to try
Offline Fairlane514
Re: Starter bolts
« Reply #5 on: May 08, 2012, 06:36:51 am »
Larger bolts may not fit in the starter. Also be sure and shim the starter if necessary. Heli coil may be the only option, it works well if done right.
Offline rickyharp
Re: Starter bolts
« Reply #6 on: May 08, 2012, 07:11:03 am »
It is the bolt hole,the bolts are new and the starter is new I think I am going to give the heli-coil a shot.I just never installed one before.
Offline 454Man
  • Why Race?
Re: Starter bolts
« Reply #7 on: May 08, 2012, 09:07:53 am »
Its really ready just take your time when threading the holes. Font let the drill get away from you sideways and your good
Offline rickyharp
Re: Starter bolts
« Reply #8 on: May 09, 2012, 07:31:53 am »
Thanks for the info I am going to try it next week and I will let everybody know how it goes.
