73-87 Chevy & GMC Trucks
Need help
Topic: Need help (Read 12676 times)
muddjar
Need help
May 10, 2012, 12:56:30 pm »
This is my 81 short wide I am in search of a new rearend and was wandering if I could upgrade to a newer style if any would fit. Its a 10 bolt I looked in rearend and the only staped numbers I seen were 89 b and 8370 so how to tell what gears I have thanks
DustyRusty
Re: Need help
May 10, 2012, 05:00:47 pm »
What's wrong with the 10-bolt? Is it broken? These aren't bad axles. However a 12-bolt from this era of truck shoult be a direct swap and will provide a little extra strength.
Since you already have the diff cover off you can determine the ratio by dividing the number of teeth on the pinion into the number of teeth on the ring gear. Ex.: Say there are 10 teeth on the pinion and 41 on the ring gear, you would have a 4.10:1 ratio, etc. Sometimes the ratio is stamped on the ring gear itself but based on your post it appears that it wasn't.
Last Edit: May 10, 2012, 05:35:14 pm by DustyRusty
1975 K-10 SWB Fleetside - 350/SM465/NP205/D44F 12-boltR, 3.73 gears. Original owner.
Customized by rust.
muddjar
Re: Need help
May 10, 2012, 09:33:11 pm »
Thanks dusty I Jacked her up and rotated the wheel and she has 273. So I went to a junkyard today and found a 12 bolt but it is in a diesel truck so does that matter just wandering
Blazin
Blazin new trails!
Re: Need help
May 10, 2012, 11:28:08 pm »
Motor doesn't matter as far as rear axle goes. Pull the cover off and check the ratio the way Dusty said. Or if it has numbers stamped in the edge of the ring gear its usually the last two numbers separated by a : divide the smaller number into the larger one.
You will need a cross over U joint. one side fits your drive shaft, the other fits the 12 bolt yoke. 12 bolts uses a little bit shorter cross, and smaller caps than a 10 bolt.
What is wrong with your current rear axle?
muddjar
Re: Need help
May 10, 2012, 11:50:26 pm »
It has a lot of slack. U no I 'spin the wheel and it takes awhile to start to move and the person I bought it from ran it with out fluid
Blazin
Blazin new trails!
Re: Need help
May 11, 2012, 06:13:49 am »
? U no? U joint?
gto109
Re: Need help
May 11, 2012, 12:03:16 pm »
I think he ment "you know"
85 Scottsdale k-10 305 700r4,
86 Trans Am 305 350th
06 Dodge Ram daily driver
muddjar
Re: Need help
May 11, 2012, 04:54:32 pm »
Just wandering if I could use the chunk out of a 4 wheel drive in mine I was told as long as it is a 10 bolt. Is that right please help
Blazin
Blazin new trails!
Re: Need help
May 12, 2012, 12:47:29 am »
4 wheel drive axle is the same. Just need to swap your backing plates, and brakes onto it. Slide you axles in, put your drums, and wheels on.
bake74
Re: Need help
May 12, 2012, 10:17:14 am »
Or see how much a local shop can fix yours for if you can not, or do not want to fix it.
74 k10, 77k10 Tom
muddjar
Re: Need help
May 13, 2012, 12:45:29 am »
Someone said that my rearend was a 28 spline but I can't find a 28 spline for a Chevy so what do I do. How can I order the ring & pinion if it don't show that they have it
Re: Need help
May 13, 2012, 07:29:17 am »
No offense but you don't sound ready to tackle a ring and pinion swap on your own. Find a 73-87 C series 5 lug axle with the ratio you want and swap it in.
Re: Need help
May 13, 2012, 10:42:36 am »
gto109
Re: Need help
May 13, 2012, 04:18:50 pm »
I agree with Vile.
muddjar
Re: Need help
May 14, 2012, 12:05:17 am »
I have looked for one they all have the same gears in them. Do I get a 30 spline will it work or will I have to change axles
Need help
