Interior & Equipment
Instrumentation
Oil Pressure Sending Unit?
Topic: Oil Pressure Sending Unit? (Read 63484 times)
Shawn0331
May 12, 2012, 12:36:44 am »
My oil pressure gauge hasn't worked since I got my truck. I'd like to know what's going on. The gauge is pegged all the way out and doesn't move.
Will
this
solve my problem?
Or is there a different solution?
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
bd
Re: Oil Pressure Sending Unit?
May 12, 2012, 02:13:59 am »
If you have factory GM gauges, you have an open in the sender, sender wiring or gauge connection to PC board. With ignition ON try jumping the sender wire directly to a good ground and see if the gauge drops to zero.
May 12, 2012, 08:27:17 am »
Agreed, is the wire connected?
Shawn0331
May 12, 2012, 08:50:39 am »
I'm headed to my dad's today to do the passenger-side ball joints. I'll take a look then.
On an '87 I need to look behind the distributor and by the oil filter, right?
bd
May 12, 2012, 09:51:55 am »
Look both places, but gauge sender should be the one near the oil filter.
Shawn0331
May 12, 2012, 10:48:48 am »
Looked under the truck just now. Is this it?
bd
May 12, 2012, 11:29:00 am »
You're pointing at the O
sensor. I don't see the oil sender in your pix. Do you see a wire dangling loose anywhere near the oil filter? Take a look next to the distributor and snap a pic.
Is that freeze plug showing a little rust?
jason d o
May 12, 2012, 11:34:45 am »
That looks like the oxygen sensor. I have an 86 model myself and my sending unit is by distributor. I'm sure mine is different from yours. I'm sure somebody will chime in here and give you a good picture at where it is.
Shawn0331
May 12, 2012, 08:50:45 pm »
This maybe?
454Man
Why Race?
May 12, 2012, 09:10:49 pm »
Its right behind the distributor... To the right alittle
May 13, 2012, 12:48:27 am »
drivers side right behind the distributor, that second one is the knock sensor
Shawn0331
May 13, 2012, 08:06:46 am »
Really appreciate all the help. I'm learning a lot!
Fairlane514
May 13, 2012, 09:55:36 am »
Thats also the wrong part from Oreilly's you refer to in your first post. You will need the one for the factory GM gauge, not Auto Meter.
May 13, 2012, 10:39:24 am »
yours should look like this
http://www.autozone.com/autozone/parts/Duralast-Oil-Pressure-Switch/1986-Chevrolet-C10-1-2-ton-Sub-2WD/_/N-ij14dZ8znc6?itemIdentifier=158014_124004_0_5673
Shawn0331
May 28, 2012, 01:27:57 pm »
Trying to find this elusive oil pressure sending unit to the right of the distributor... Is this disconnected wire supposed to connect to it?
I'm not seeing anything else interesting to the right of the distributor.
Instrumentation
