th400 swap questions
Topic: th400 swap questions (Read 6645 times)
ncguy89
May 15, 2012, 12:32:58 pm »
ok guys i got another question. i got a 84 chevy k10 with a th350/np203 converted. im swapping in a th400/208 into the truck. i know the th350/203 was not factory in this truck but it was in the truck when i bought it. now these are my questions.
1. the np203 in the truck has a slip yoke on the rear driveshaft. can i reuse this driveshaft and have a 32 spline yoke put on it for the np208?
2. instead of a cable i know the th400 has a solenoid. what is this switch that goes on the gas pedal called so i can buy one? is it called the trans kickdown solenoid switch (
http://www.rockauto.com/catalog/moreinfo.php?pk=45109
3. the np203 in the truck now has 2 square rubber mounts. i bought a mount through oreilly's part number 2638 because its like the mounts i have seen before. will this mount work for the th400?
any help is greatly appreciated and if i can get these questions answered then i can have my dd back up and running in a day. thanks alot guys!!!
Last Edit: May 15, 2012, 12:40:13 pm by ncguy89
1987 v20 - 350 tbi with towing cam, hummer wheels, stock otherwise
1984 chevy c-10 shortbed - kidney foundation truck (for my father)
Re: th400 swap questions
May 15, 2012, 08:03:49 pm »
search on here for detent solenoid
⌠ŻŻŻŻŻ' [☼===☼]
ncguy89
May 15, 2012, 09:43:25 pm »
i figured out the switch i needed. now for the other 2 questions can anyone help?
bake74
May 16, 2012, 06:28:34 am »
There is a difference in length between the two trans and transfer case setups. So your drive shaft will have to shortened. (depending on how long your tail shaft is on your th350, they came in different lengths).
From what I can remember, the 208 at my shop and the 203 in my truck looked like they have the same or close to the same rubber mount for the cross member. But I have not yet did the switch so I am not positive.
74 k10, 77k10 Tom
ncguy89
May 16, 2012, 11:17:21 am »
ok i appreciate the help. ill get it over to the ds shop today.
May 20, 2012, 04:34:09 pm »
Do you have the shifter and the crossmember for the 208? Your best bet is a donor. Is this a long or short bed?
⌠ŻŻŻŻŻ' [☼===☼]
ncguy89
May 20, 2012, 08:37:58 pm »
yea i had all of that. i got everything in just waiting on the rear driveshaft and got to fix a wiring
problem.
