Author Topic: What engine is this?  (Read 7771 times)
Offline Shawn0331
    • My Blog
« on: May 15, 2012, 07:20:20 pm »
I got a free complete engine from a friend who said a guy swapped it out for an inline 6. He has no idea what it is other than its an sbc.
I'm guessing it's a 305 because its got 5.0 on the side. Correct?
Here's the numbers I got off it:
Block:
14093627
J306
V1031CLH
It also has a Quadrajet carb on it:
17087129
2826 jsc
Intake:
14101074
I've looked up all these numbers on Google and can't seem to narrow it down.
1987 Chevy V10 Silverado SWB 5.7 on 33x12.5's
http://www.shawnseeley.com
Re: What engine is this?
« Reply #1 on: May 15, 2012, 07:53:47 pm »
305
Offline Shawn0331
    • My Blog
« Reply #2 on: May 15, 2012, 07:55:01 pm »
« Reply #3 on: May 16, 2012, 03:00:09 am »
5.0
« Reply #4 on: May 16, 2012, 03:27:44 am »
305 87-94 2 bolt, Roller or flat tappet cam, one-piece rear seal date 09/30/86, the intake came off a 82-92 chevy car hope that helps just a little more
« Last Edit: May 16, 2012, 03:32:10 am by Irish_Alley »
Offline Shawn0331
    • My Blog
« Reply #5 on: May 16, 2012, 08:39:24 am »
Thanks. How and where did you figure that out?
« Reply #6 on: May 16, 2012, 09:45:27 am »
14093627 block casting number
J306 build date
Offline Shawn0331
    • My Blog
« Reply #7 on: May 16, 2012, 11:27:23 am »
I looked up the CLH suffix code on chevymania.com and it says it's from an '87 Chevelle L-69.
Would that be a viable engine to keep to swap with my current 350?
Does it have enough power to push around my '87?
Offline jaredts
« Reply #8 on: May 16, 2012, 12:08:51 pm »
It has enough power, but a 350 makes more sense IMHO.  If you have access to a cylinder leakdown tester you could check it out.  If all cylinders show minimal leakdown you could put it in as a cheap way of getting around, but don't expect much.
Offline Shawn0331
    • My Blog
« Reply #9 on: May 16, 2012, 12:13:42 pm »
I'll ask my neighbor if he's got one. Thanks.
