Author Topic: Engin ID Help PLease!  (Read 4445 times)
Offline RickyRodder
« on: May 16, 2012, 02:01:32 pm »
have an 83 Chevy with a TBI V8. Not sure if it's a 350 or 305. The numbers on the front are K0615FBC and under that is CH7179158. I can't find the FBC on any of the suffix code websites. Any help with this would be greatly appreciated.
Offline klaussk
Re: Engin ID Help PLease!
« Reply #1 on: May 16, 2012, 04:09:25 pm »
If it is the original motor you might be able to look it up using the VIN.
Go ahead hit it with a hammer. Theres only one level of broke.
« Reply #2 on: May 16, 2012, 07:23:12 pm »
the block codes are next to the distribitor above the bell housing
Offline RickyRodder
« Reply #3 on: May 16, 2012, 07:33:43 pm »
It's not original. It was a 305 carb truck originally. I think it came out of an early 90's chevy. I will look behind the distributor for block numbers tomorrow. I thought you could tell by the numbers on the front behind the alternator bracket.
Offline RickyRodder
Re: Engine ID Help PLease!
« Reply #4 on: August 27, 2012, 07:04:59 am »
10054727  numbers on the block behind distributor on transmission mounting flange I can't find these numbers on the list
« Reply #5 on: August 27, 2012, 04:25:23 pm »
It should have a 5.0L  or a 5.7L  on it.
« Reply #6 on: August 28, 2012, 05:37:04 pm »
10054727    1986-up    350       2/4    one piece rear seal, some "Made in Canada"
K0615FBC
K   St. Catherines, Ontario
06 = June
15 = 15th
No idea on the FBC suffix.  Does it really matter?  It is just a regular 350 Block like all the others.
