Engin ID Help PLease!
Topic: Engin ID Help PLease! (Read 4321 times)
RickyRodder
May 16, 2012, 02:01:32 pm »
have an 83 Chevy with a TBI V8. Not sure if it's a 350 or 305. The numbers on the front are K0615FBC and under that is CH7179158. I can't find the FBC on any of the suffix code websites. Any help with this would be greatly appreciated.
klaussk
Re: Engin ID Help PLease!
May 16, 2012, 04:09:25 pm »
If it is the original motor you might be able to look it up using the VIN.
Go ahead hit it with a hammer. Theres only one level of broke.
May 16, 2012, 07:23:12 pm »
the block codes are next to the distribitor above the bell housing
RickyRodder
May 16, 2012, 07:33:43 pm »
It's not original. It was a 305 carb truck originally. I think it came out of an early 90's chevy. I will look behind the distributor for block numbers tomorrow. I thought you could tell by the numbers on the front behind the alternator bracket.
RickyRodder
Re: Engine ID Help PLease!
August 27, 2012, 07:04:59 am »
10054727 numbers on the block behind distributor on transmission mounting flange I can't find these numbers on the list
zieg85
August 27, 2012, 04:25:23 pm »
It should have a 5.0L or a 5.7L on it.
August 28, 2012, 05:37:04 pm »
10054727 1986-up 350 2/4 one piece rear seal, some "Made in Canada"
K0615FBC
K St. Catherines, Ontario
06 = June
15 = 15th
No idea on the FBC suffix. Does it really matter? It is just a regular 350 Block like all the others.
