Author Topic: What size wrench on brake bleeders  (Read 15112 times)
Offline powerT
« on: May 18, 2012, 01:54:56 pm »
What size wrench for the back bleeders
Offline howlinwolf
Re: What size wrench on brake bleeders
« Reply #1 on: May 18, 2012, 02:07:10 pm »
5/16 typically
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Offline DnStClr
« Reply #2 on: May 18, 2012, 03:34:46 pm »
If it's been a while since the brakes were bled, you might have to wire brush the threads and squirt some penetrating fluid on em. I like to use a flare nut wrench on the bleeders. It seems to grip better.
Don
87 Chevy Silverado
Offline jaredts
« Reply #3 on: May 18, 2012, 04:31:25 pm »
I think my '83 had 10mm.
« Reply #4 on: May 18, 2012, 04:58:26 pm »
     This is a excellent suggestion, if you want to avoid a major headache later by rounding out the nut part on the bleeder.  Either a line wrench or a six point closed end wrench.
« Reply #5 on: May 18, 2012, 08:29:01 pm »
You can put a 6 point socket on these bleeders so there is no need for a wrench to break them loose
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: May 18, 2012, 09:12:20 pm »
I'm thinking a 5/16 or 10mm.  Depends on who rebuilt the cylinder the last time.  Could be either or.  Most are, 3/8 front 5/16 rear.   could be metric if the company who supplied the cylinder/caliper last time decided to use that standard.  If you have a decent set of MM/SAE combo wrenches, you'll be ok.
Offline howlinwolf
« Reply #7 on: May 18, 2012, 11:00:40 pm »
but the offset wrenches are nice and not that expensive.
i finally bought one.
Offline 1979C20
  • Kyle Taulton.
« Reply #8 on: May 19, 2012, 01:05:07 am »
My fronts are 3/8ths and rears are 10mm.
« Reply #9 on: May 19, 2012, 06:18:58 am »
Its the size wrench that fits the best!. If they are rusted or rounded off a selection of twist sockets will be your best bet.
