TH400 yoke
Topic: TH400 yoke (Read 9334 times)
schulerboy
TH400 yoke
June 11, 2012, 12:47:11 am »
Can a turbo 400 tranny with the bolt in yoke be changed to a slip yoke? The reason I am asking is because I am not sure if I should go with a one piece driveshaft or a two piece.
Re: TH400 yoke
June 13, 2012, 10:46:54 am »
I don't remember off hand but I think there is a yoke available for this.
schulerboy
Re: TH400 yoke
June 13, 2012, 06:52:42 pm »
Good to know! I will have to do more research.
zieg85
Re: TH400 yoke
June 14, 2012, 11:01:12 am »
I think I remember the rear internal output shaft is different between the bolt on and slip yoke type TH400. I read it somewhere but I can't remember the source.
scorpion
TH400 yoke
June 15, 2012, 05:41:44 am »
I think this is what you're looking for:
http://www.dennysdriveshaft.com/p69_t_400__4l80_transmission_slip_yoke_1310_series_32_spline_wth.html
From the site:
1310 Series 32 spline T-400 & 4L80 Transmission Slip yoke specifically designed to be used on a T-400 & 4L80 with the Threaded Hole in the center of the Output shaft. 1310 Series 32 spline T-400 & 4L80 Transmission Slip yoke specifically designed to be used on a T-400 & 4L80 with the Threaded Hole in the center of the Output shaft. This design will replace the truck style bolt on yoke with a car style slip yoke and allow for proper slip travel and bushing contact for best performance. With this slip yoke you can now use a normal car style driveshaft.
Part #: 2060662 $125.95 each
schulerboy
Re: TH400 yoke
June 17, 2012, 02:04:48 pm »
Yes that is what I was looking for. Thanks for the link!
TH400 yoke
