Author Topic: Driveshaft  (Read 6305 times)
Offline RicoTizzio
Driveshaft
« on: June 16, 2012, 02:48:00 pm »
Installed a 700 in my 84 Chevy that had an overdrive trans from the factory. Should my org shaft fit perfectly in there or will i need modification. Is there a junk yard fix lol
Re: Driveshaft
« Reply #1 on: June 17, 2012, 04:37:14 pm »
     Are you talking about the A833 4 speed overdrive unit ?  If so then no, your driveshaft more than likely will need modifications unless both transmissions were close in length.
Offline RicoTizzio
Re: Driveshaft
« Reply #2 on: June 22, 2012, 01:14:15 am »
That i don't know,i was going by the factory book that came with it n using the vin numb
Offline slammed79
  • Thou shalt not drive stock
Re: Driveshaft
« Reply #3 on: June 22, 2012, 11:00:35 am »
Drive shafts are almost impossible to find in junkyards here. One of the local shops quoted me $350 for a steel, one piece shaft, 57" long.
Try craigslist or have one made.
Praise the lowered
Offline RicoTizzio
Re: Driveshaft
« Reply #4 on: June 22, 2012, 11:04:40 am »
Thanks will do
Re: Driveshaft
« Reply #5 on: June 25, 2012, 02:42:30 am »
the junk yard i worked at we had a rack just for drive shafts. the only problem is trying to match the yokes up
Offline RicoTizzio
Re: Driveshaft
« Reply #6 on: June 25, 2012, 07:06:10 pm »
My factory yoke will go in the tail but its rusty so id like to clean it any ideas
Offline thirsty
    • Suitor's Garage
Re: Driveshaft
« Reply #7 on: June 26, 2012, 08:18:16 am »
Those are made from some pretty good steel. It takes a lot of rust to make them pitted. Clean it up with something like brake-kleen then use about 180 grit paper to get most of the rust off without making it shiny. Switch to emery cloth and polish it up. Check it for pitting or damage to ensure it doesn't eat your seal up. I had to do the same thing to mine after it sat for a long time in a shed and rusted. I was upset when I found it that way but after 10 minutes of work it was good.
Offline RicoTizzio
Re: Driveshaft
« Reply #8 on: June 26, 2012, 02:39:57 pm »
Sounds like a plan. But will the same steps work on the inside of the yoke
