Author Topic: separated rear 3/4 ton spring  (Read 4395 times)
Offline cwest
« on: June 18, 2012, 10:08:01 am »
I bought an 86 Chevy 3/4 4X4 this winter, I'm not trying to get fancy with it, just restore/replace anything that needs it back to factory specs.  The left rear leaf spring(8leafs) is a little separated, it is causing the left rear side of the truck to lean a little.  It has a hefty pair of helpers on top, so I imagine it was overloaded at some point and just over stretched the pack.  I'm trying to find the best route to replace both rears.  If I go to a spring shop could they produce an exact replica of the factory set for me, or should I just order them from  ?  They seem to charge a lot for shipping though.  I could def go the cheap route and hit up a junk yard, but I think a new set would look sharp.
Be gentle, I'm new at this restoring thing, any info would be helpful.  Thx
86' Chevy K20
350/SM465/np208
08' Silverado 1500 4X4 WT
Offline Donut
Re: separated rear 3/4 ton spring
« Reply #1 on: June 18, 2012, 04:28:43 pm »
Contact the local spring shop and see what they'd charge.  If they can't reproduce what you have, they should be able to get it.
Personally, I'd get a good set (inspect and make sure they're not in the same condition as yours) from a junkyard, pull them apart and clean 'em up.  If nothing else the spring shop could hook you up with a new centerbolt and u-bolts.
I'm not around much, or much into the "proper" restoring, just keeping them going.
Welcome.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline cwest
« Reply #2 on: June 18, 2012, 09:15:15 pm »
I'm with ya, I'm only replacing things that need fixed, it's in great stock shape as is so pretty much already how I want it.   I'll start looking around for a good spring shop, and maybe call some junkyards.  Thanks for the reply.
86' Chevy K20
350/SM465/np208
