Author Topic: th350 to sm465  (Read 25875 times)
Offline Farm boy
th350 to sm465
« on: June 27, 2012, 07:35:17 am »
I have a 86 k10 with a 350, a bad th350 tranny, and a np208 t-case. I also have a 80 k10 that I am parting out with the same setup but a np205. So I want to swap the 86 over to a sm465 and the 205 t-case and i was wondering how close the sm465 is to the th350 in length and if the rear bolt pattern is the same as the th350 so I have an idea what kind of mods to expect.
I was going to use the my6 but when I got to thinking about it the truck has 3.42 gears, and it already has 33" tires and i will be going to 35s at some point. Most of the time I will be driving within 30min of my house, with an occasional trip to Toledo (45 min) and an airsoft field (1 hour). So I figured it would make sense to go with the sm465 instead. If there is something missing in that line of thought let me know.
« Last Edit: June 27, 2012, 09:34:19 am by Farm boy »
K10-350 w/Holley 4bl, 350th, 33-12.5-15s, blue)-parting out
K10-350 w/Holly 4bl, bad th350 swapping to sm465, 33-12.5-15s, CAMO!
Re: th350 to sm465
« Reply #1 on: June 27, 2012, 10:11:52 am »
     In my 74 k10 I am going with a MY6 trans with 35" and 3.73 gears, I figure at highway speeds I will be in the 2000 - 2200 rpm range which will help a lot with my MPG.
     As far as the swap you are talking about, the SM465 trans is shorter I believe than the TH350, so mods will have to be done to drive shaft, and you will have to install all the clutch linkage for the SM465.
Offline Farm boy
Re: th350 to sm465
« Reply #2 on: June 27, 2012, 12:55:08 pm »
using a online calculator you should be around 1,500 with that setup, and mine will be around 2,000. I think I'll go with the sm465 since i will probably be doing a lot of modding ether way, and it looks like i won't be doing too bad on rpms.
Quick question. On the sticker in the glove box it says on the tranny line: 1mxo  4 spd. auto. trans. Does that mean it had a 4spd auto or a sm465 and the auto means something else?
Here is the calculator i used: http://vexer.com/automotive-tools/speed-rpm-calculator
Offline Jason S
Re: th350 to sm465
« Reply #3 on: June 27, 2012, 11:54:38 pm »
Your truck likely had a 700R4 transmission from the factory which was replaced with a TH350 at some point.  If you were to install the SM465 and NP205, you'd have a pretty stout setup.
Offline Farm boy
Re: th350 to sm465
« Reply #4 on: June 28, 2012, 09:01:45 am »
Well i just found a sm465 and np205 combo for $250 so i am going to get that and just sell sell mine. So why would you switch a 700r4 out for a th350? unless it was bad and they had a th350, but still. The other thing is there is a closed in hole in the floor in what sounds like the right spot and shape for a sm465 shifter, but then i don't see anything left over from the clutch petal; so i really don't know what it had.
Offline thirsty
    • Suitor's Garage
Re: th350 to sm465
« Reply #5 on: June 28, 2012, 09:23:13 am »
86 had a hydraulic clutch. If yours was a manual it would have a hole next to the wiring bulkhead.
Re: th350 to sm465
« Reply #6 on: June 28, 2012, 09:36:26 am »
     As Jason S pointed out, that means that your truck came with a 700r4 transmission.  That is the overdrive version for out trucks in the auto trans.
     If you plan to swap to a SM465, your best bet is going to be to get a donor truck that is a stick, because your truck will have none of the parts for a clutch, it will all bolt up to your truck, it will just be easier to swap from one truck to another instead of going after parts a hundred times.
Offline Farm boy
Re: th350 to sm465
« Reply #7 on: June 28, 2012, 05:50:32 pm »
Yah I agree but the guy I am getting it from has a lot of that kind of stuff or knows where to get it, and he is about 5 miles from me. That and my dad doesn't the 80 k10 sitting around any longer than it needs to (parting it out). Plus the best reason of all: I am almost wiped out from buying the second truck so I don't have the money to buy another one.
So if it had a auto tranny, what is the hole in the floor that looks like it's for a shifter?
Offline Fairlane514
Re: th350 to sm465
« Reply #8 on: June 28, 2012, 10:38:10 pm »
4WD...........transfer case shifter?
Offline Farm boy
Re: th350 to sm465
« Reply #9 on: June 29, 2012, 10:07:56 am »
I don't think so. I will just stop describing it, get a pic, and post back in 10-15 min.
Offline Farm boy
Re: th350 to sm465
« Reply #10 on: June 29, 2012, 10:31:00 am »
ok here is a pic of the closed in hole
Offline thirsty
    • Suitor's Garage
Re: th350 to sm465
« Reply #11 on: June 29, 2012, 11:04:30 am »
Looks like it is the location for a SM465 just not cut out from the factory.
In these pics you can see the factory cut out for a SM465.
Offline Farm boy
Re: th350 to sm465
« Reply #12 on: June 29, 2012, 11:52:47 am »
It looks like it's welded, and the floor has spray-on bed liner on it. So i don't know what it is but i know that is going to be opened back up ;)
Re: th350 to sm465
« Reply #13 on: July 02, 2012, 02:27:04 pm »
That stamping is in most floors for pickups.
Offline Farm boy
Re: th350 to sm465
« Reply #14 on: July 07, 2012, 07:35:27 am »
Ok i guess that makes sense. So one more question: could you guys help me out with my list of parts?
So far here is what i have:
-trans
-hydro shift bell housing
-slave cylinder
-clutch fork
Here is what i know i need to get
-clutch kit
-flywheel
-master cylinder
-hose/fittings
-clutch pedal
So what else do i need and how much of that should i get used or buy new?
