Body, Glass & Paint
Cab removal with 2 post lift
Topic: Cab removal with 2 post lift (Read 11332 times)
kmanrsss
July 14, 2012, 08:20:15 pm »
Well ive bitten the bullet and good, bad or otherwise im pulling the cab to wire brush and paint the frame and replace fuel and brake lines. anyways whats the best way to lift the cab off the frame with a 2 post lift. I have to replace rockers and some floor plus the drivers side floor support and body mount so a little damage to those areas arent an issue. this is my first time so any tips are appreciated. thanks
slammed79
Thou shalt not drive stock
Re: Cab removal with 2 post lift
July 14, 2012, 10:56:17 pm »
Soak the can mount bolts with pb blaster or a similar product a couple days before, those can bolts are quite happy where they are, and will need some persuasion to get out.
Praise the lowered
kmanrsss
July 14, 2012, 11:10:53 pm »
ive already got all the bolts out, and all the wiring disconnected. im looking more for suggestions on lift points, blocking etc. i was starting to wish i hadnt bought an 87 today with all those plugs under the hood.
slammed79
July 14, 2012, 11:19:15 pm »
The pinch welds will do just fine for a lift point, just get your arms as far apart as possible. Then fire safety, roll the frame out and drop the lift back down.
Have you built a cab dolly? It'd be helpful for keeping your cab square while replacing structural components.
Praise the lowered
thirsty
July 15, 2012, 07:28:13 am »
How are your door bushings and pins? Does the door fit and work properly? If so you should drill some alignment holes in your hinges so that you can put the door back on to check the fitment of the new parts.
A cab dolly is a good idea too. Just make sure it is stable and won't rack on you while you are working on it or moving it around. When I did the metal work on my cab, I did a lot of it with the cab on the truck and then put it on a dolly to finish it off. And bolt the cab to the dolly to avoid a disaster too.
Good luck with it and keep us up to date on how it is going. Don't forget that I have some parts here waiting for you.
Build thread
kmanrsss
July 15, 2012, 08:25:49 pm »
Thanks for the tips. Ive got it off and it seemed to go well. Hopefully I labeled everything well enough and will get her running again. I am thinking about doing the frame cleaning/painting and putting the cab back on the chassis and going from there. I have not forgotten Thirsty, i appreciate it just need to find some time. We are having our 1st child here in 5 weeks give or take and as you can imagine between work and baby home prepping things are very hectic. I will keep you all posted as this build will hopefully go quickly as i need the truck for plowing this winter. Ill post some pics when i get them resized
kmanrsss
July 17, 2012, 08:01:28 pm »
Whelp I've done it now. I picked up an 83 cab that's in great shape. Solid floors, decent paint, and great rockers and corners. Only issue is its a 2wd cab but I think that tunnel change out is easier the cab corners and rockers. Plus it hides easier if I screw it up. I do have a 2 inch body lift in the garage that I may use. Not sure yet. I think this should save me time.
thirsty
July 18, 2012, 06:04:27 am »
I think a 2" body lift will give you the clearance that you need. Easy enough to try if you have a lift. If you have a NP208 though using your old hump will give you a perfect transfer case shifter hole already done for you.
Build thread
Body, Glass & Paint
