Author Topic: 67 c10 3 speed set up  (Read 22655 times)
Offline hotrod24
« on: July 16, 2012, 05:26:07 pm »
Ok i am getting a straight 6 and 3 speed out of a 67 c10. Will the 3 speed work and all the linkages and driveshaft work in my 80?
1978 pontiac grand prix...
Online zieg85
Re: 67 c10 3 speed set up
« Reply #1 on: July 16, 2012, 05:32:15 pm »
No the wheel base is different (assuming both are longbeds) so the drive shaft/s won't work.  The 67 probably had a coil spring rear suspension with a 2 piece drive shaft.  The shifting linkages for the column 3 speeds also differ as the 80 style is very close to what the automatic is on the 1st./reverse side so it can be locked in reverse with the key out of the ignition.
Offline hotrod24
« Reply #2 on: July 16, 2012, 06:23:49 pm »
They both are short beds and the 67 has leafs in the rear.... So what would i need?
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: July 16, 2012, 06:36:51 pm »
Easiest way is going to be making it a floor shift 3 speed, unless you have a 3 on the tree now. You'll need to find a stick shift truck and get the pedals, firewall brace and linkages.
At this point in your project I wouldn't yet worry about it and get the rust repair done correctly. Just my .02
Praise the lowered
« Reply #4 on: July 16, 2012, 10:17:37 pm »
The transmission if it has provisions for a transmission mount is the only thing that will interchange from the older trucks.
Offline hotrod24
« Reply #5 on: July 16, 2012, 10:46:13 pm »
So the only thing from the 67 that would be any good to me is the 3 speed it self?
Online zieg85
« Reply #6 on: July 16, 2012, 11:08:12 pm »
No, the straight 6 will work if you don't need to pass any emission requirements.  The bell housing usually had the mounts and the transmission just hung out there just bolted on to the bell housing.
Offline hotrod24
« Reply #7 on: July 16, 2012, 11:17:28 pm »
OK so i just need to get the straight 6 and the 3 speed?
http://c10forum.com/forum/showthread.php?t=14175&page=2
« Reply #8 on: July 17, 2012, 05:35:12 am »
Sorry it was late, and I missed the motor part of your post. The motor will work as well as long as it has the casting in the block for the newer style motor mounts. As zieg said some of the older cars and trucks the motor ismounted by the bell housing, and two points near the harmonic balancer. The trans didn't have a mount. If this is how the 67 is mounted check and se if the block will accept the side motor mounts like your truck has, and see if the trans has the same mounting flange as yours.
Offline hotrod24
« Reply #9 on: July 28, 2012, 10:24:13 am »
OK i know this is off topic but i have a 78 3 speed column and i am going to get a 80 column and build a good column out of both of them. I have manuals that show diagrams, but I can not figure out if they are 3 speed columns are automatic because they do not say.  What is the difference between an automatic and a manual 3-speed column??
Online zieg85
« Reply #10 on: July 28, 2012, 12:25:21 pm »
The manual column will have 2 levers where the linkages hook up on the outside near the firewall.
Offline hotrod24
« Reply #11 on: July 28, 2012, 01:19:22 pm »
How about the internals?
Online zieg85
« Reply #12 on: July 28, 2012, 03:09:55 pm »
Never had one a part but I would imagine they are quite different.
Offline hotrod24
« Reply #13 on: July 31, 2012, 12:32:13 pm »
Heres a pic of the inline 6 so you can see the motor mounts...
Online zieg85
« Reply #14 on: July 31, 2012, 01:06:07 pm »
Got to love the simplicity of the I-6
