Author Topic: confused about my block  (Read 22293 times)
Offline 86gmc23
« on: July 21, 2012, 11:39:18 pm »
Just bought a old motor from a guy, he said it was a 350. I ran the numbers GM 14010207 and CFD 207. 14010207 States its an 1980-85 350 from a truck, however the CFD comes up as 1982 305. Do I have a 350 or a 305?
Offline winky
Re: confused about my block
« Reply #1 on: July 21, 2012, 11:47:30 pm »
I believe all the 350 say 5.7 on the back right behind where the heads sit
« Reply #2 on: July 29, 2012, 12:49:42 pm »
i hate to say it, cant take someones word on anything nowdays
Offline 305chevy c-10
« Reply #3 on: July 29, 2012, 06:33:35 pm »
if it dont have it there check top of bellhousing where tran bolt on should be stamped there gm 5.7 .all chevy blocks dont have 5.7 or 350 stamped on them i forgot what year they started so on them type blocks u just gotta run the # .or just pull off the head and see if u have a 4'" bore or better if its been bored .3.74 +/- it is a 305
Heartbeat of America yesterday's cheverolet
18T5C10
Offline 78chevyshortbed
« Reply #4 on: December 12, 2012, 03:16:51 pm »
i have the same exact thing and im quite confused.
Offline chengny
« Reply #5 on: December 13, 2012, 04:04:30 am »
GM block casting number 14010207 =
Manufactured 1980-85
350 CID
2 or 4 bolt main
Primarily for truck applications
Offline pholliday1
  • 1990 V3500 Crew Cab
« Reply #6 on: December 13, 2012, 07:16:14 am »
For what it's worth I have seen people put 305 heads on a 350 to "try" to increase compression.
« Reply #7 on: December 13, 2012, 12:41:07 pm »
Casting number is a 350.
« Reply #8 on: December 16, 2012, 10:06:42 am »
arnt the valves different tho?
« Reply #9 on: December 16, 2012, 01:02:14 pm »
305 heads have smaller combustion chambers (more compression) and smaller valves (less flow at higher rpm)  They don't help a larger motor at all.
