confused about my block
Topic: confused about my block (Read 22290 times)
86gmc23
July 21, 2012, 11:39:18 pm »
Just bought a old motor from a guy, he said it was a 350. I ran the numbers GM 14010207 and CFD 207. 14010207 States its an 1980-85 350 from a truck, however the CFD comes up as 1982 305. Do I have a 350 or a 305?
winky
Re: confused about my block
July 21, 2012, 11:47:30 pm »
I believe all the 350 say 5.7 on the back right behind where the heads sit
July 29, 2012, 12:49:42 pm »
i hate to say it, cant take someones word on anything nowdays
305chevy c-10
July 29, 2012, 06:33:35 pm »
if it dont have it there check top of bellhousing where tran bolt on should be stamped there gm 5.7 .all chevy blocks dont have 5.7 or 350 stamped on them i forgot what year they started so on them type blocks u just gotta run the # .or just pull off the head and see if u have a 4'" bore or better if its been bored .3.74 +/- it is a 305
Heartbeat of America yesterday's cheverolet
18T5C10
78chevyshortbed
December 12, 2012, 03:16:51 pm »
i have the same exact thing and im quite confused.
chengny
December 13, 2012, 04:04:30 am »
GM block casting number 14010207 =
Manufactured 1980-85
350 CID
2 or 4 bolt main
Primarily for truck applications
pholliday1
1990 V3500 Crew Cab
December 13, 2012, 07:16:14 am »
For what it's worth I have seen people put 305 heads on a 350 to "try" to increase compression.
December 13, 2012, 12:41:07 pm »
Casting number is a 350.
December 16, 2012, 10:06:42 am »
Quote from: pholliday1 on December 13, 2012, 07:16:14 am
arnt the valves different tho?
December 16, 2012, 01:02:14 pm »
305 heads have smaller combustion chambers (more compression) and smaller valves (less flow at higher rpm) They don't help a larger motor at all.
