Author Topic: Gas tank options for 86 shortbox  (Read 3967 times)
Offline project1
« on: July 23, 2012, 04:29:28 am »
Is it possible to install a larger gas tank on the driver side and do away with the passenger side one?
Re: Gas tank options for 86 shortbox
« Reply #1 on: July 23, 2012, 05:47:40 am »
Anything is possible with time, and money. If you wanted to move your fill into the wheel well a long bad tank might be able to be shoehorned in there to gain a few gallons.
Why do you not want duel tanks?
Offline slammed79
  • Thou shalt not drive stock
« Reply #2 on: July 23, 2012, 09:37:30 am »
16 gallon is your limit on with the shortbox, unless you do a Blazer tank swap, you can fit a 30 gallon tank behind your axle, and do away with saddle tanks all together.
Praise the lowered
Offline project1
« Reply #3 on: July 23, 2012, 08:16:18 pm »
Thankyou for the help I guess I will stay with the duel tanks then I dont have to mod anything!
