Author Topic: 700R4 speedometer adaptor seal  (Read 3824 times)
Offline Fairlane514
« on: July 23, 2012, 08:06:45 pm »
Anyone have any luck with part numbers for the "O" ring and the small seal?
I have NAPA, Oreilly, Advance auto and Auto Zone near me.
Re: 700R4 speedometer adaptor seal
« Reply #1 on: July 23, 2012, 08:43:30 pm »
Speedo sleeve O/R, GM/AC Delco P/N-15552872
Speedo driven gear seal, GM/AC Delco P/N-1361618
Be sure to check the driven gear and sleeve for wear; that's usually what causes them to leak.
Offline Fairlane514
« Reply #2 on: July 23, 2012, 09:30:27 pm »
Thanks for the numbers, hopefully I will have it pulled tomorrow and I will know which drive gear I need.
Is the sleeve a replaceable part, or do I need to get the whole adaptor assembly?
« Reply #3 on: July 23, 2012, 10:01:32 pm »
The sleeve (driven gear support) is serviceable.  There are two P/Ns with different offsets, depending on the number of teeth on (diameter of) the driven gear.
