Author Topic: 1st time painter  (Read 6399 times)
Offline str8bloc
  • MISTRESS
1st time painter
« on: August 01, 2012, 05:52:14 pm »
well i wanna shoot my truck soon. i am gonna buy a gun weds and look for a primer which primer can i shoot and drive for a while so i can slowly paint my truck piece by piece until i get a satin blue truck?
FaTbOy
Re: 1st time painter
« Reply #1 on: August 01, 2012, 08:31:33 pm »
If it is going to be out in the weather most primer should be expected to last, are you planning on sanding it down and then priming it and driving it?
Offline Sartobuilt
« Reply #2 on: August 01, 2012, 08:36:23 pm »
Most primers aren't meant to seal, the primer will absorb moisture. It needs to be sealed if not painted.
Offline str8bloc
  • MISTRESS
« Reply #3 on: August 01, 2012, 08:38:29 pm »
yea its my daily so on the weekends i plan on sanding then prob 3-5 coats of primer until the truck is complete in primer then ill paint the whole truck satin blue when on vacation in a few months.hows the duplicolor paintshop line any good?
FaTbOy
« Reply #4 on: August 01, 2012, 08:47:43 pm »
You need to put primer sealer on there and then plan to re-prime it when it is time to paint it all.
Offline DustyRusty
« Reply #5 on: August 02, 2012, 03:55:10 pm »
Use an epoxy primer, it is not porous.  It will not absorb water.  Therefore, you can drive it and continue to work on it piece by piece.  IIRC, PPG makes a blue epoxy primer that may be similar to the desired effect you're trying to achieve.
Customized by rust.
« Reply #6 on: August 02, 2012, 05:23:19 pm »
I ran my truck with just epoxy for about a year, and while it is not as bad as primer, it will not last very long and you will still will end up needing to reprime it before painting.
