Body, Glass & Paint
1st time painter
Topic: 1st time painter (Read 6400 times)
str8bloc
MISTRESS
1st time painter
August 01, 2012, 05:52:14 pm »
well i wanna shoot my truck soon. i am gonna buy a gun weds and look for a primer which primer can i shoot and drive for a while so i can slowly paint my truck piece by piece until i get a satin blue truck?
FaTbOy
Re: 1st time painter
August 01, 2012, 08:31:33 pm »
If it is going to be out in the weather most primer should be expected to last, are you planning on sanding it down and then priming it and driving it?
Sartobuilt
August 01, 2012, 08:36:23 pm »
Most primers aren't meant to seal, the primer will absorb moisture. It needs to be sealed if not painted.
str8bloc
MISTRESS
August 01, 2012, 08:38:29 pm »
yea its my daily so on the weekends i plan on sanding then prob 3-5 coats of primer until the truck is complete in primer then ill paint the whole truck satin blue when on vacation in a few months.hows the duplicolor paintshop line any good?
FaTbOy
August 01, 2012, 08:47:43 pm »
You need to put primer sealer on there and then plan to re-prime it when it is time to paint it all.
DustyRusty
August 02, 2012, 03:55:10 pm »
Use an epoxy primer, it is not porous. It will not absorb water. Therefore, you can drive it and continue to work on it piece by piece. IIRC, PPG makes a blue epoxy primer that may be similar to the desired effect you're trying to achieve.
1975 K-10 SWB Fleetside - 350/SM465/NP205/D44F 12-boltR, 3.73 gears. Original owner.
Customized by rust.
August 02, 2012, 05:23:19 pm »
I ran my truck with just epoxy for about a year, and while it is not as bad as primer, it will not last very long and you will still will end up needing to reprime it before painting.
Body, Glass & Paint
1st time painter
