Author Topic: 4" lift questions  (Read 17152 times)
Offline Chevy Truck Guy 86
4" lift questions
« on: August 13, 2012, 08:38:44 pm »
I was going to buy a 2" lift for my 86 K10 but for some reason the 4" is $80 cheaper so I'm getting that kit. But will I need to get  sway bar drop brackets for this? I read somewhere on here that you don't need a raised steering arm. And I'll worry about the drive shafts later. Any replies would be great.
If there was no rust when you restore a vehicle, it would be to easy.
Offline Sartobuilt
Re: 4" lift questions
« Reply #1 on: August 14, 2012, 08:17:12 am »
I would look into the raised steering arm, you want the drag link as level as possible to eliminate bumpsteer. Don't use the s shaped drag link they tend to twist. As far as the sway bar i would try the one ORD has, http://www.offroaddesign.com/catalog/swaybarkit.htm .
« Reply #2 on: August 14, 2012, 04:13:44 pm »
Thanks, where should I get the steering arm from then?
Offline Sartobuilt
« Reply #3 on: August 14, 2012, 04:31:12 pm »
Same place http://offroaddesign.com/catalog/steeringcorrection.htm They have alot of good quality parts for our trucks.
« Reply #4 on: August 14, 2012, 05:42:50 pm »
Thanks again for the help.
« Reply #5 on: August 14, 2012, 08:51:43 pm »
So if I were to get a 2" lift would I still need to get something for the sway bar?
« Reply #6 on: September 05, 2012, 10:53:13 am »
I don't think you would need it for a 2" lift, but check with the lift manufacturer.
« Reply #7 on: September 05, 2012, 11:32:17 am »
http://www.roughcountry.com/chevy_4wd_77-87_4.html
its all you need
the sway bar drop is not needed but is recommended and only $36 i would go for it but we just hooked my buddys k5 4" lift and just bolted the stock brackets up with no problem.
Offline 81_Chevy
« Reply #8 on: October 07, 2012, 08:12:05 pm »
i just put a 4 inch lift in myself, as far as steering compenets wise you can you a raised steering arm, drop pitman arm, or an s shaped drag link, thats the one i have and it doesn't twist at all. the reasoning behind the steering stuff is that when you put the lift in, from the power steering pump to the axle you loose 4 inches of steering to the right. figured that out the hard way LOL. we left the sway bar alone and it is all good.
« Reply #9 on: October 08, 2012, 07:12:14 am »
     Some points to think about for any suspension lift/lowering.
     First and most important, what are you planning on doing with your truck that you need a suspension lift ?  Looks, off roading, mudding ?
     Second you should always build to what you have planned for the truck, even if it is in stages.
     Third, you should always try to buy the suspension kit that includes the shocks, most of the time they are valved for the lift ( not all lifts are the same on how they ride after installed).
     Forth, always cycle your lift and truck while parked ( I like to use a forklift to pick up each tire for flex) to see if any brake lines or such need lengthen or there will be any binding issue's ( like drive shafts ).
Offline CruzinHigh
  • Chevy 4 life
« Reply #10 on: October 10, 2012, 09:32:28 pm »
Looks like this post is sorta dead but since it was recently resurrected....
Big question and one of the most important imho.  What size tires are you gonna run?
Mike Carter
1986 Chevy K-10 4x4
Offline 81_Chevy
« Reply #11 on: October 17, 2012, 11:02:56 am »
x2
