Author Topic: pulling distributer  (Read 8696 times)
Offline jaredbs
pulling distributer
« on: August 28, 2012, 07:17:29 pm »
ok.. i havent posted here much if at all.... but i have read thru plenty and have found alot of valuable info!!
so here is my issue..  1977 chevy stepside.. 305/350 auto.  i am doing a cam, intake and carb change.. my distributor will not pull out!!!  the intake is loose, hold down and bolt out from dist base.. i have pulled, twisted, wiggled, pryed ... it will not even turn!!  it ran fine before i started this project.. am i missing something?? plz help!!
Offline Sartobuilt
Re: pulling distributer
« Reply #1 on: August 28, 2012, 09:00:45 pm »
Someone must have used some sillicone on it, if you have the clamp off it shuld pull loose.
1. maybe use channel locks just below the base and try to twist it.
2. If there is enough room pull the intake with the distributer and deal with it afterwards.
Offline jaredbs
« Reply #2 on: August 28, 2012, 09:08:17 pm »
i have tried a 1" wrench to turn it, with no luck...pry bar....off the empty intake man......ive put penatrating oil on it by the can..  i think its stuck on cam or on the oil pump shaft...  i really didnt want to pull the pan and handle it from there..
Offline Fairlane514
« Reply #3 on: August 28, 2012, 11:14:13 pm »
You may just have to keep repeating the process of penetrating oil (overnight) and channel locks or the 1 inch wrench until it breaks free.
Offline Sartobuilt
« Reply #4 on: August 29, 2012, 07:51:43 am »
If it is not twisting, that leads me to belive its stuck on the intake manifold. See if you can slice it at the base with a razor blade. I cant see it getting stuck in the cam or oil pump shaft, even if it was you would be able to twist it. Since you have the intake loose, can you lift the intake straight up a little bit that will tell you if its stuck to the cam or pump shaft. Is this a known running engine? If it sat the distributer could be locked up in the bosses in the block.
Offline Fairlane514
« Reply #5 on: August 29, 2012, 10:02:44 am »
This may be a long shot..........if the intake is loose and slightly up it may be locking the shaft of the distributor. In other words maybe its got it torqued because the hole is no longer exactly vertical.  The cam gear and the distributor gear are locked as well at the oil pump shaft, if the distributor shaft is being  pushed forward or backwards.
« Reply #6 on: August 29, 2012, 01:41:05 pm »
Was the truck running prior?  Is the cap and rotor off?  Is it rusty inside.  I have had to put a prybar on my 90 Burb to get the distributor out and it was so bad, I just replaced it.
Offline jaredbs
« Reply #7 on: August 29, 2012, 05:23:33 pm »
truck was running ok, i have the dist. turning now.. but it turns hard.. im going to keep hitting it with penatrating oil and turning it for awhile and see what happens..   i have put a 3' pry bar on it and gave it all i had and nothing..
Offline Sartobuilt
« Reply #8 on: August 29, 2012, 08:26:01 pm »
Try two prybars on either side on the valvecovers and give it a pop.
Offline Sartobuilt
« Reply #9 on: August 29, 2012, 08:31:55 pm »
The hole in the intake is alot larger than the distributer body, its locked in the bosses in the block. Spraying lube isnt going to get into the boss in the block. The dist body is alumnium and when it corodes it swells. Your going to have to use some delicate force.
Offline 454Man
  • Why Race?
Re: Re: pulling distributer
« Reply #10 on: August 29, 2012, 09:43:14 pm »
x2
« Reply #11 on: August 30, 2012, 09:44:02 pm »
pull the intake off, see what you messing with
Offline Sartobuilt
« Reply #12 on: August 31, 2012, 10:09:13 am »
I dont think he can get the intake off, the distributer is stuck in the bosses in the block.
« Reply #13 on: August 31, 2012, 12:22:28 pm »
Try using something a little stronger, like Berrymans B12.  Flood it in around the base of the distributor so that it trickles down the outside of the distributor shaft toward the oil passage area.  Continue to work the distributor both around and up-and-down.  Alternate with some PB Blaster.  Eventually you should cut through the gum and varnish and pull it free.  If you have access to a slide hammer, use a "fork" under the upper housing and pop it free that way.  Snap-On makes (made) a distributor puller attachment just for this purpose.  Though rare for Chevy, this used to be a common problem with Ford small blocks.
Offline jaredbs
« Reply #14 on: September 04, 2012, 03:09:27 pm »
i got it!  took two evenings and a 3ft pry bar and a 2lb hammer.. AND i didnt hurt anything!!
it may have also took a couple beers......
