Author Topic: Spark Plug Wires Not Long Enough  (Read 4736 times)
Offline Harmon
« on: October 07, 2012, 09:00:57 am »
I got a 86 chevy with 350 and I got some new plug wires.  It sems the pass side 4,6,8 plug wires rest on the heat shield for the exhaust manifold....surely I dont have the wrong wire set...anyone have any experience on this?
Re: Spark Plug Wires Not Long Enough
« Reply #1 on: October 07, 2012, 09:22:39 am »
Have you tried routing them under the manifold from around back?  I am assuming everything is original?  A 350 would mean a 3/4T?
« Reply #2 on: October 07, 2012, 11:49:22 am »
are they resting on the heat shield or they are so tight they are stretch across the heat shield
« Reply #3 on: October 07, 2012, 12:09:44 pm »
What makes you so sure you have the right set? If they don't match up to the last set than they're not right, right?
« Reply #4 on: October 07, 2012, 10:11:35 pm »
I agree. Check them against the old ones, providing the old ones clear everything.
Offline rchaneyk10
« Reply #5 on: October 08, 2012, 07:08:02 pm »
I've had this problem with wires from advance auto parts.
