Author Topic: 85' C10  (Read 2822 times)
Offline Jakissel
85' C10
« on: October 16, 2012, 07:18:04 pm »
I recently purchased a 1985 C10. Truck is currently with the factory 305 engine. I'm wondering if a Chevy 350 4 bolt main with fit right in and work with the current factory transmission?
85' C10 Classic Deluxe.
Re: 85' C10
« Reply #1 on: October 17, 2012, 12:03:44 am »
There is no difference between any small block Chevy of any cubic displacement, all of them interchange, the only gotchas are the 86-up 1 piece seal, and then the only difference is a different flywheel.
The number of main bolts are not a factor.
Re: 85' C10
« Reply #2 on: October 17, 2012, 12:55:02 am »
The dipstick is on the right hand sisde of the motor for a one piece rear main seal. Its on the left hand side for a two piece rear main seal motor.
Offline 9511234
Re: 85' C10
« Reply #3 on: November 02, 2012, 11:42:46 am »
If you plan to use a mechanical fuel pump you'll want to make sure the block is prepped for it.  All blocks have the outside mounts, but not all are drilled through.
