Author Topic: upgrading my truck.. need help  (Read 5073 times)
Offline winky
« on: October 18, 2012, 07:59:53 pm »
looking to upgrade my running gearneed help on deciding what to go for... here are some specs..
350 engine (building a beefed up 350 for it though)
700r4 trans, would like something more reliable (truck is purely a play toy not worried about gas consumption because of no overdrive)
37" super swapers
208 t case
stock front and rear end i believe 3.73 gears?
6" susp lift 3" body ( i know this doesnt really affect too much but maybe pinion angle would be worse on something?)
any ways i want every ones input on what i should buy for my truck.. no im not rich and i dont have a ton of money but i would rather save up and buy the right stuff than have to tear down my truck every time i go play in it..
i mainly play in the mud but i DO have a heavy foot lol, also i tend to be the only guy with decent mud tires around here so i play recovery a lot lol so i want something that will hold up and not break but also dont want to kill my check book. i would appreciate any help and input
Re: upgrading my truck.. need help
« Reply #1 on: October 19, 2012, 02:19:38 pm »
As long as it is slippery mud, you should be fine especially if you are only and occasional recovery truck.
If the 700R4 is old, and worn out, rebuilt it would definitely be reliable.
Offline Magic1
« Reply #2 on: October 20, 2012, 08:54:57 am »
I found this if it helps ya out. Gear Ratio
Size   3,31   3,42   3,55   3,73   3,91   4,11   4,27   4,56   4,88   5,13   5,29   5,38   5,71   6,17   7,17
30   2410   2490   2584   2715   2846   2992   3109   3320   3553   3735   3851   3917   4157   4492   5220
31   2332   2409   2501   2628   2755   2896   3008   3213   3438   3614   3727   3790   4023   4347   5051
32   2259   2334   2423   2546   2669   2805   2914   3112   3331   3501   3610   3672   3897   4211   4894
33   2191   2263   2349   2469   2588   2720   2826   3018   3230   3395   3501   3561   3779   4083   4745
34   2126   2197   2280   2396   2512   2640   2743   2929   3135   3295   3398   3456   3668   3963   4606
35   2065   2134   2215   2328   2440   2565   2664   2845   3045   3201   3301   3357   3563   3850   4474
36   2008   2075   2154   2263   2372   2493   2590   2766   2961   3112   3209   3264   3464   3743   4350
37   1954   2019   2095   2202   2308   2426   2520   2692   2881   3028   3123   3176   3370   3642   4232
38   1902   1966   2040   2144   2247   2362   2454   2621   2805   2948   3040   3092   3282   3546   4121
39   1854   1915   1988   2089   2190   2302   2391   2554   2733   2873   2962   3013   3198   3455   4015
40   1807   1867   1938   2037   2135   2244   2331   2490   2664   2801   2888   2937   3118   3369   3915
44   1643   1698   1762   1851   1941   2040   2119   2263   2422   2545   2626   2670   2834   3063   3559
The tire size is the column running down the left and gear ratio is running across the top. All the other numbers are the rpm at which it would be at 65 mph.
« Last Edit: October 20, 2012, 09:00:08 am by Magic1 »
Offline winky
« Reply #3 on: October 20, 2012, 09:19:18 am »
Thank you, I found a set of one tons for $1200 ( wife will probably flip lol)
« Reply #4 on: October 22, 2012, 09:29:03 pm »
That isn't that bad a price if it is a good D60 and 14B...
Offline winky
« Reply #5 on: October 24, 2012, 09:43:45 am »
Ok so the guy said he was interested in trading. I have some 37" tsl boggers about 75-85% tread on 15" aluminum bullet holes would that be an even trade or what? Was wanting some input, what would y'all ask for if you were in my shoes
« Reply #6 on: October 30, 2012, 10:29:18 pm »
Try it and see.  I don't know what yours look like, so...
Offline winky
« Reply #7 on: October 31, 2012, 08:42:03 pm »
