Author Topic: 87 tbi 305 est issues  (Read 3695 times)
Offline rusty but trusty
« on: October 20, 2012, 08:11:18 pm »
Hello i have a issue with my electronic spark timing system. with the bypass wire unhooked i have the timing set to 0. but when i hook the wire up it runs very bad mostly backfiring and running rough the wire between the ecm and connector shows some resistance between it alone and unhooked from everything but not a lot what would be a good place to look? for the short
87 GMC V1500 305 700R4 NP208 and 10 bolts front and rear
Offline roboticjunky
Re: 87 tbi 305 est issues
« Reply #1 on: October 21, 2012, 09:40:22 am »
Did you check your knock sensor and the wire going to it?
1987 V10 Silverado 350 HSR
« Reply #2 on: October 21, 2012, 10:33:04 am »
The wiring and the knock sensor are both good but the est wire from the ecm to connector under hood seems to be partially grounded
« Reply #3 on: October 21, 2012, 10:50:53 am »
I wonder how your timing chain is?
« Reply #4 on: October 21, 2012, 12:44:29 pm »
Quote
Can you be specific about what you are measuring resistance on and why? Verify everything primary and secondary ignition is good and fuel pressure is good. If so check the ECM, prom, ground and EST module.
« Reply #5 on: October 21, 2012, 06:37:07 pm »
the resistance i measured was on the wire that goes through the firewall to the ecm and i completely un hooked it on both ends and it has only a little resistance from it to ground like it was grounded before it goes where it goes
