Body, Glass & Paint
slip on outter rocker...
Topic: slip on outter rocker... (Read 16938 times)
hotrod24
October 22, 2012, 05:01:00 pm »
OK last week I ordered a kick panel from chris and I removed the old one and all and started to fit the new one. Now I am having some trouble with lining it up and the fit...
Here it lines up pretty good but the bottom where the fender bolts up, will not line up and the pinch weld on the kick panel seems not to be wide enough where the the rocker goes up into the piller...
Ok here it lines up better but the bottom where the inner rocker goes sticks up passed the outer rocker...
Last Edit: May 18, 2013, 11:44:53 am by hotrod24
1978 pontiac grand prix...
gildardo01
Re: kick panel fit...
October 22, 2012, 07:13:30 pm »
woah seems like you have a rust problem on the truck.... the good thing about metal is that you can cut it up and bend it until it fits and just weld everything in place....
October 22, 2012, 07:55:28 pm »
It being a little over isn't going to be an issue, just trim it back, BUT is the hole on the bottom lined up with the rocker hole? Is that a factory rocker? Has it been replaced. Just trying to figure out what the history is of what we are working on.
Blazin
Blazin new trails!
October 22, 2012, 09:19:44 pm »
I would keep the door jamb, and the floor plain lined up. You can trim the under side, and you can over size that bottom fender bolt hole if need be.
hotrod24
October 22, 2012, 09:41:20 pm »
Yea gildardo01. This 80 has alot of rust in some unusal places I would like to weld every thing but I dont have a welder I will be getting one this winter tho. I can still do a little triming but I want to be for sure that is what needs to be done. Chris as far as I know the truck still has the factory rocker and in the 5th pic the kick panel will almost line up with the rocker hole. Blazin what is a floor plain?
Last Edit: October 22, 2012, 09:44:18 pm by hotrod24
Blazin
Blazin new trails!
October 22, 2012, 10:07:19 pm »
The plane of the floor metal. Where the floor would hit the kick panel if it wasn't rusted away.
Last Edit: October 23, 2012, 06:18:57 am by Blazin
October 22, 2012, 10:11:35 pm »
I think Blazin is talking about the plane as in level... It looks good to me from those pics if everything is as close as you say it is.
hotrod24
October 25, 2012, 07:18:04 pm »
Yea I am going to be making the floor pan so that will have the floor plane, mine is long gone except about an inch at the top. Anyway I have been back at it and I am still kinda lost lol. I think since I am trying to put a repo kick panel with a stock rocker is my problem but not sure. This is how it is going to have to be for now I just dont know what needs to be done...
Should I trim the peace that sticks up passed the rocker?
I lined this one up today and I think it fits the best...
October 30, 2012, 10:18:34 pm »
That back edge where it is clamped needs to be flush, if that tang in the bottom is in the way, trim it down.
Gearhead1
Its not much, but its all I've got
November 13, 2012, 11:29:35 am »
holy crap, and i thought i started with a rusty cab!!
Sartobuilt
November 13, 2012, 06:06:42 pm »
A cab that has been drivin with that much rust is gonna be out of wack. If it was me I'd find a better cab. You'll save money by not getting a welder and patch panels. Post some pictures of the rest of the cab.
November 13, 2012, 06:58:34 pm »
Most replacement panels are going to be slightly off that's just the way it is. A little persuasion and some seam sealer will make it look good as new when you're done.
hotrod24
Reply #12 on:
November 14, 2012, 08:00:55 pm »
Yea gearhead1. It has alot of rust lol. Sartobuilt what areas you need of the cab? Vile I know what you mean about these panels being off. The good news is that I fitted the kick panel best that I could and I am starting to put panels together but I am having some problems with the inner rocker fitting with the floor support and kick panel? I think it is suppost to go in between the inner rocker and kick panel?
Reply #13 on:
November 15, 2012, 06:38:31 pm »
Did you see this thread?
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5661.0
hotrod24
Reply #14 on:
November 15, 2012, 07:13:35 pm »
Yep chris I sure did. I cannot get it to line up right like it is in the pics. Every time I jack the cab up like in pic 2 and 3 then the inner rocker is to high. So I must be doing something wrong...
Body, Glass & Paint
