Body, Glass & Paint
Aligning barn doors....
Topic: Aligning barn doors.... (Read 7709 times)
1979C20
Kyle Taulton.
October 29, 2012, 10:32:20 pm »
It seems as though the only adjusting that can be done on the barn doors is in and out. I need my driver side door to rotate clockwise and eighth inch and move right some. I also think it needs to go down a bit. I couldnt tell you why they are so misaligned.... What kind of adjusting can be done on them?
Re: Aligning barn doors....
October 30, 2012, 09:32:32 pm »
What year Suburban? There should be some adjustment in the mounting bolts for tilt.
1979C20
Kyle Taulton.
October 30, 2012, 11:58:46 pm »
Its my 89. The only adjustment i can see are the bolta where the hing mounts to the body and to the door. 3 bolts on each side of all 4 hinges. Geometrically speeking, i can only adjust the doors in and out, but not left or right.
PromiseKeeper
October 31, 2012, 09:46:53 am »
Is there some slop in the hinge pins? It almost sounds like you have some sag going on. New bushings may be in order
1980 C-10 2WD short & wide. 305 auto.
1979C20
Kyle Taulton.
November 01, 2012, 08:20:54 pm »
There is no slop or sag at all. Ive tried lifting tge diors and it move the whole truck.
PromiseKeeper
November 05, 2012, 09:00:21 am »
I'd try some shims behind the hinges and see what happens
1979C20
Kyle Taulton.
November 07, 2012, 01:46:16 am »
I think it would be quite difficult to get a shim in there. Although, I was able to adjust it a little bit by pulling down on the top of the door. Now I just need to adjust it in some and adjust the strikers. Thanks guys.
Body, Glass & Paint
