Author Topic: tranny filler tube  (Read 2648 times)
Offline 77 cc lb
tranny filler tube
« on: November 17, 2012, 12:11:15 pm »
Does anyone have any tricks for sealing the tranny filler tube on a th400, or any trannny? Also, about how much fluid should come out of the tranny when you pull out the vacuum modulator? Haynes manual says a little, but about a pint came out when I pulled it off. Any info would be great, Thanks.
87 Chevy crewcab shortbed soon to have a 454/400
Re: tranny filler tube
« Reply #1 on: November 17, 2012, 05:18:39 pm »
Your questions lead me to believe your dipstick and or dipstick tube is the wrong one and you are over filling it causing both conditions... My $.02 which won't buy you much but give you something to check...
Offline 77 cc lb
« Reply #2 on: November 20, 2012, 03:34:44 pm »
The truck had been sitting awhile and there was an excessive amount of fluid leaking. I checked it out and the filler tube bracket was broken and it had come out of the tranny a little, plus I think it was a overfilled. Thanks for some info zieg 85.
