Author Topic: scat connecting rod bolts  (Read 5550 times)
Offline bake315
« on: November 17, 2012, 08:14:47 pm »
Hey guys,
I bought a new set of Scat connecting rods from Summit, and was trying to install my bearings, but when I attempted to remove the rod bolts, I discovered I couldn't because they are EXTREMELY tight.  As in "bent a wrench" tight!  Is this normal?
« Last Edit: November 17, 2012, 09:50:15 pm by bake315 »
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline gildardo01
Re: scat connecting rod bolts
« Reply #1 on: November 17, 2012, 09:47:57 pm »
ive used ARP and thats never happen.....
Offline gildardo01
« Reply #2 on: November 18, 2012, 07:25:27 am »
by the way how many ft lb did you tighten them in the first place....
Offline bake315
« Reply #3 on: November 18, 2012, 02:14:34 pm »
None.  They came sealed in plastic like that, new in the box.
Offline gildardo01
« Reply #4 on: November 18, 2012, 03:25:44 pm »
i thought they came unassembled like the ARP ones... and you went ahead and tighten them on the rods....
Offline bake315
« Reply #5 on: November 18, 2012, 03:58:59 pm »
Not on these, apparently.  I've only unwrapped one so far.  I think I'm going to unwrap a second one to see if it's the same way.  If it is, I'm going to have to get creative... maybe blocks of wood in a vise to protect the rods so I can apply more torque...
Offline gildardo01
« Reply #6 on: November 18, 2012, 05:03:04 pm »
well if you bent a wrench... thats a lot of torque unless the wrench is made in Taiwan or China, and when you put them on the rods you only tighten them at about 45lb so why would they be tighter than 45ft lb when they come from the warehouse... seems odd.... like i said never used scat bolts... i guess there is no other way than to use the vise and apply more torque... might want to check for damaged threads after....
« Reply #7 on: November 18, 2012, 11:54:34 pm »
Offline bake315
Offline gildardo01
« Reply #9 on: November 21, 2012, 07:23:47 am »
so did you ever get them loosened?
Offline bake315
« Reply #10 on: November 21, 2012, 09:07:36 am »
Yep, sure did.  Clamped 'em up between a couple of 2x4 blocks in my vise and that allowed me to get them loose with minimal effort.  Main bearings arrived yesterday also, so with my long weekend I should be able to get a fair amount of assembly done.
