Author Topic: Sm465 input shaft leak  (Read 13002 times)
Offline Senck243
« on: November 21, 2012, 03:16:36 pm »
After ruling out a rear main seal i now know the puddle is coming from the front of the transmission and is probably an input shaft seal? I am going to pull the transmission hopefully before the clutch gets too oil soaked. any tips? i have never pulled a transmission. Truck is an 84 with a sm465 with hydraulic clutch and a np208. just don't want to mess up anything because of a trick i didn't know. thanks for the help
1984 k10 305, sm465, np208
Offline juicedimpss
Re: Sm465 input shaft leak
« Reply #1 on: November 22, 2012, 02:11:54 pm »
probably easier to pull the engine,than to fight with the cast iron trans with transfer case.
Offline thirsty
    • Suitor's Garage
« Reply #2 on: November 22, 2012, 03:37:15 pm »
Drain the 208 before you separate it from the transmission. Be aware that when you pull the 208 back it will want to roll. They aren't terrible heavy. The SM465 on the other hand is heavy. Be careful when you pull that out. Also put the SM465 in neutral before removing the shift lever.
Offline Senck243
« Reply #3 on: November 22, 2012, 07:58:07 pm »
Thanks fellows. I have a tranny jack so it will make it a lot easier. I appreciate the help.
Sent from heck
Offline Senck243
« Reply #4 on: November 23, 2012, 05:07:53 pm »
Ok guys got the tranny and transfer case out today. There is gear oil all over the front of the tranny looks like the cover under the input shaft plate
Sent from heck
Offline Senck243
« Reply #5 on: November 23, 2012, 08:04:17 pm »
Anything else i should replace while I have it out besides the clutch?
Sent from heck
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: November 23, 2012, 09:04:37 pm »
Anything else that leaks. Check the freeze plugs on the back of the motor as well.
Offline Senck243
« Reply #7 on: November 24, 2012, 04:33:13 pm »
Thanks very much
Sent from heck
Offline slammed79
  • Thou shalt not drive stock
« Reply #8 on: November 24, 2012, 07:14:09 pm »
This would be a good time to check your rear main seal too.
Praise the lowered
Offline bake315
« Reply #9 on: November 27, 2012, 10:23:53 am »
Sent from heck
Check the input shaft bearing retainer itself for cracks.  Sometimes people torque these down too far, not realizing that it's easy to break them.  Once that's done, a new one must be bought, otherwise you'll continue to have leaks.
« Last Edit: November 27, 2012, 10:25:25 am by bake315 »
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
Offline Senck243
« Reply #10 on: November 27, 2012, 04:13:07 pm »
Thanks bake
Sent from heck
