Engine/Drivetrain
Engine Id help
Topic: Engine Id help (Read 4660 times)
Cruz.cab
Engine Id help
November 26, 2012, 09:00:07 pm »
I know the numbers are true the are very ligible
Block casting 3970010
Tab on passenger head 251524731 k07029r
I know it's a 350 bc of the block casting p.o did purchase an engine but not sure from we're ?
bake74
Re: Engine Id help
November 26, 2012, 09:02:39 pm »
Do a Internet search for engine I'd numbers. They will give you the size, and year ranges. Same with the heads.
74 k10, 77k10 Tom
Cruz.cab
Re: Engine Id help
November 26, 2012, 09:37:55 pm »
I've tried for what seems like 2 hours I can only find the block castin info
bake74
Re: Engine Id help
November 27, 2012, 04:54:17 pm »
Alright, I am one for someone doing their own work, but since you looked and nobody else chimed in here is a good start. I did not find the exact numbers you listed, but if you read up on this article it will explain to you what it all means, and in the mean time someone with a reference book might chime in.
Chevy engine casting numbers
http://www.crankshaftcoalition.com/wiki/Chevy_engine_casting_numbers
And if you hit the SBC cylinder head identification Crankshaft Coalition wiki article, under Chevy head casting numbers it will take you to the section on heads. Good luck and I am sure someone will chime in.
74 k10, 77k10 Tom
zieg85
Re: Engine Id help
November 27, 2012, 05:09:41 pm »
I would have chimed in but I usually see 2 or 3 letters at the end which then makes sense. Here is the resource I use. The engine was built in Canada but beyond that I can't help, sorry
http://www.nastyz28.com/chevy-engine-code-stampings.php
Last Edit: November 27, 2012, 05:14:47 pm by zieg85
Cruz.cab
Re: Engine Id help
November 27, 2012, 05:51:31 pm »
Thanks for the help guys !!
Engine/Drivetrain
Engine Id help
