Author Topic: Screws/bolt to hold vent housing behind dash  (Read 3871 times)
Offline FarTooJones
« on: December 03, 2012, 07:30:52 pm »
I just received a new dash from this site and was trying to install it. I removed the plastic vent housing that is attached behind the dash in the middle and right side, but when i went to reattach those pieces to the new dash i discovered they were just simply screwed into the old dash. I would prefer to use the holes provided on the plastic piece and the new dash. Is it just  simply a nut and bolt that holds it on? The right side has three holes and the piece in the middle has 3 as well.
« Last Edit: December 03, 2012, 09:21:39 pm by Captkaos »
Re: Screws/bolt to hold vent housing behind dash
« Reply #1 on: December 03, 2012, 07:50:10 pm »
They are held on by threadcutting nuts and when you say you purchased it from this site you mean this website? http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=7&Category_Code=DC
Offline FarTooJones
« Reply #2 on: December 03, 2012, 07:54:39 pm »
yes correct, i got the $325 dash on the bottom
