Author Topic: Rear end swap?  (Read 9260 times)
Offline 86c10
Rear end swap?
« on: December 14, 2012, 08:57:41 am »
My truck currently has a 2.73 10 bolt and I have a 3.73 12bolt sitting around and was wondering if there is any way to figure out what might happen to my mileage if I switch. I'm getting about 15 mpg now with a stock 305/350 and the 2.73. Most of the roads where I use the truck are 55-65mph, not much intown starting and stopping.
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Rear end swap?
« Reply #1 on: December 14, 2012, 01:50:58 pm »
It's gonna get worse..........LOL you knew that already, My guess is about 2mpg. But look at the good side the truck will feel like you have 35-50 more hp.
Offline gildardo01
Re: Rear end swap?
« Reply #2 on: December 14, 2012, 05:57:05 pm »
you wont need a first gear anymore...
Re: Rear end swap?
« Reply #3 on: December 15, 2012, 08:41:28 am »
X2
Offline 86c10
Re: Rear end swap?
« Reply #4 on: December 15, 2012, 07:34:56 pm »
Yeah unfortunately I thought that it would get worse, but like you said it will feel like it has more power. I can probably live with 2 mpg less, the truck just gets used to run to Lowe' and Homedepot.
Thanks
Offline 86c10
Re: Rear end swap?
« Reply #5 on: December 16, 2012, 08:19:03 am »
Will the stock drive shaft be the right length?
Offline Jason S
Re: Rear end swap?
« Reply #6 on: December 16, 2012, 05:17:25 pm »
You should be able to use the stock driveshaft if your just swapping 10 to 12 bolt.
Re: Rear end swap?
« Reply #7 on: December 17, 2012, 07:51:39 am »
You will need a hybrid u-joint though...
Offline 86c10
Re: Rear end swap?
« Reply #8 on: December 17, 2012, 10:04:14 am »
Will a parts guy know what I'm talking about If I tell him what I'm doing? Or do I need to ask for a specific part number?
Re: Rear end swap?
« Reply #9 on: December 23, 2012, 02:00:13 pm »
He should know what you want unless they are under the age of 25.,..
Re: Rear end swap?
« Reply #10 on: December 24, 2012, 09:26:52 am »
     If your 10 bolt is the standard 1310 u joint series and the 12 bolt is the standard larger 1330 series this is what you can use.   http://www.summitracing.com/parts/PCN-253/
     This web site will give you measurements of each side so you can measure them and double check that this one will work.
« Last Edit: December 24, 2012, 09:28:51 am by bake74 »
Offline Dave C.
Re: Rear end swap?
« Reply #11 on: December 26, 2012, 11:38:03 am »
Don't you need to change the rear wheels as well?  I thought that only the 4wd models had the 12 bolt.
Re: Rear end swap?
« Reply #12 on: December 30, 2012, 12:49:57 pm »
every thing prior to 1981 used 12 bolts, everything after used 10 bolts (an yes there are exceptions as they were using up the remaining 12's)
Offline 86c10
Re: Rear end swap?
« Reply #13 on: December 31, 2012, 11:30:08 pm »
Thanks, bake I will look into that when I get closer to the swap. I'll have to wait on better weather, I'm working outside in the drive way.
That helps, now I know who to stay away from.
As far as I know the 12 bolts came as 5 lug 2wd and 6 lug 4wd, and the axle shafts will change from one housing to the other. I'm sure somebody will chime in if I'm wrong.
That explains my '83 that I parted out. Was 3.73 a factory option in the 1/2 ton trucks?
Offline thirsty
    • Suitor's Garage
Re: Rear end swap?
« Reply #14 on: January 01, 2013, 08:15:41 am »
I had a K10 with 2.73 once. I had plenty of motor in that truck so I could somewhat live with it. I used the truck for a daily driver. I wheeled a lot then but never took that truck off road other than hunting or work. I put some new all terrain type 33's on it and got to say that I got pretty decent mileage and it was one of the best short wheel base trucks that I ever drove in the snow. I didn't have that rust bucket long then went back to driving my wheeling rigs year round and suffering in the snow. ;D
