Author Topic: 83 GMC K 1500 ring and pinion 10 bolt  (Read 3395 times)
Offline Medina2928
« on: December 31, 2012, 09:42:44 am »
What is the biggest gear ratio I can go with on my truck without having to change rear ends.  I would like to buy a ring and pinion set and drop in. The truck has 3.08 gears now but I  putting 33 inch tires on.  Thanks.
83 GMC High Sierra 4x4
Re: 83 GMC K 1500 ring and pinion 10 bolt
« Reply #1 on: December 31, 2012, 11:04:51 am »
http://eastcoastgearsupply.com/i-127197-gm-10-bolt-8-5-ring-pinion-yukon-gear.html says 5.13...  But remember you have to change the one up front as well...
« Reply #2 on: December 31, 2012, 11:28:06 am »
What transmission do you have?  For 33's I would go 3.73 or 4.10 depending on what transmision you have.
Offline Medina2928
« Reply #3 on: December 31, 2012, 11:44:23 am »
I have the 700r4. Which is being overhauled right now.  And yes I know you have to change both.  Thanks again.
« Last Edit: December 31, 2012, 11:47:22 am by Medina2928 »
« Reply #4 on: December 31, 2012, 12:42:29 pm »
     Anything taller and it will have the opposite effect you want.  Your engine sped will be higher when at freeway speeds you will end up burning more gas just keeping up with traffic.
