Author Topic: My 83 GMC C10  (Read 22719 times)
Offline Canadian 4X4
My 83 GMC C10
« on: January 26, 2013, 06:54:42 am »
I picked up this 83 shortbox its got a 350 with an A833OD behind it. I am planning on using it for a daily driver once it thaws, up here. It has dual flex lite Efans, hydraulic clutch set up, eldelbrock intake and new 650 holley carb. It needs a little bit of body work. Passenger front fender needs to be replaced and bottom of box behind the rear wheel. the red paint along the bottom of the whole truck has to go as well. I need to fix the way the battery is mounted as well. the previous owner was a diesel mechanic so he scooped up a cheap 31 series battery and put it there to get it mobile. I am undecided only colour at this point though. Interior needs to be put back together and hopefully this isnt going to be a wiring nightmare. Next winter I plan on bagging it and doing a stock floor body drop.
Re: My 83 GMC C10
« Reply #1 on: January 26, 2013, 11:16:22 am »
     Not a bad start at all.  How do you like the A833 ?  I picked one up for a 4x4 that I am going to put into my 74 k10, just to try to help with mpg a little.
Offline 454Man
  • Why Race?
Re: My 83 GMC C10
« Reply #2 on: January 26, 2013, 01:16:25 pm »
Cool lowrider
Offline gildardo01
Re: My 83 GMC C10
« Reply #3 on: January 26, 2013, 01:48:52 pm »
i like the stance.. how many inches of drop does it have?
Re: My 83 GMC C10
« Reply #4 on: January 27, 2013, 07:28:29 am »
I havent driven it yet, it needs a little work. but im hoping it works well and i can get 15mpg if i drive normally.
Its a 5/7 drop done with belltech components, as far as i know/can tell. other than the flip kit bracket.
Cool lowrider
thanks dude!
Re: My 83 GMC C10
« Reply #5 on: January 27, 2013, 07:30:16 am »
I fixed the flip kit that the previous owner put in. A buddy and I fixed them by cutting out some templates out of 1/4 plate with the plasma.
the original
what we made
We also made and extension for the shifter, the original only come the the bottom of the seat, the new one is about a foot taller. its made out of 1/2 .077 tube. drilled and tapped one and and drilled the other and welded a stud in. I forgot to take pics but its much more comfortable now.
truck needs lower balljoint and outer tie rod on the drivers side, have to check the brakes and order parts monday am.
Re: My 83 GMC C10
« Reply #6 on: January 27, 2013, 04:29:10 pm »
     The A833 had a shorter shifter, I already know I am going to lengthen mine.
Re: My 83 GMC C10
« Reply #7 on: January 28, 2013, 08:39:23 am »
how do you plan on modifying yours? mine is pretty hacked up but it will work for now. the biggest issue we found is that to get into reverse the stick is almost under the steering wheel
Re: My 83 GMC C10
« Reply #8 on: February 17, 2013, 03:55:47 pm »
I put lower balljoint and outer tierod on it today. I noticed that the back end has 2" hanger drop, 2" shackle drop and a flip kit in the back. On the front its got 2.5" drop spindles and the springs are cut so short that when the truck is on the hoist I can move the springs with my hand. We'll see how this thing rides. It still has bump stops on the lowers i think they will have to be cut off. The 235 75 15's are hitting the inners so I may have to raise it all up. I feel like there is no way this thing has a 9" drop in the back but my other truck is in storage and i cant get a measurement to compare it too. i cant get the hoist arms under the front with out a floor jack. so it has less than 4" of clearance at the front cab mount
« Last Edit: February 17, 2013, 04:03:02 pm by Canadian 4X4 »
Offline Marshall
  • Straight Edge
Re: My 83 GMC C10
« Reply #9 on: February 17, 2013, 06:05:50 pm »
Nice to see you on here as well as the other forum. We should cruise this summer.
Re: My 83 GMC C10
« Reply #10 on: February 18, 2013, 06:53:27 am »
     My plan is to cut the shifter below the tunnel (hump) level, re-weld a longer shifter handle onto the stubb.  First I know I will have to measure and re-measure, it will have to be bent in a couple of places.  I was going to try to copy the stick shift off my sm465 I have now.
     I won't get to that till next year though.
Re: My 83 GMC C10
« Reply #11 on: March 02, 2013, 04:20:26 pm »
got some new goodies for the truck. 88-91 grill with core support and wiring harness. a center console. a suburban rear bumper and an a/c gauge bezel
Re: My 83 GMC C10
« Reply #12 on: March 10, 2013, 07:23:49 pm »
well it warmed up quite a bit and i decided i should come out of hibernation and get some work done. I scuffed and painted my headlight bezels with flat black tremclad (rustoleum) and wire wheeled and started to prime my core support, but i ran out of primer
end result, i still have to polish up the plastic chrome tomorrow after work
wire wheeled
primed
Re: My 83 GMC C10
« Reply #13 on: March 19, 2016, 09:59:53 am »
Been away for a long time, truck took a turn not long after i last posted, i decided to cut it up and stock floor body drop it. here are a few of the pics I've snapped over the last couple years. hoping to have it together for the end of may but things always seem to come up. I've been saying it'll be ready for summer the last 3 years. I've moved to a new shop next door to my new house, so things should get better, more convenient to go work on it. I am in the middle of a 6 lug swap. I'm running 22" gm transit wheels. I'll try to keep this page updated
Offline Evolspecies
  • '84 C10
Re: My 83 GMC C10
« Reply #14 on: March 29, 2016, 06:41:51 pm »
Very nice, cant wait to see updates as you go along!
