Author Topic: Blazer fuel tank  (Read 5172 times)
Offline Trimmy
Blazer fuel tank
« on: January 27, 2013, 08:49:57 pm »
I am interested in doing a blazer fuel tank swap into my 86 while its down getting some other stuff done. ive read how to do it, not hard but no thread ive read states what years the tank comes ouf of. Sorry if this has been asked. I've searched just not found what years the tanks come out of.
« Last Edit: January 27, 2013, 08:54:24 pm by Trimmy »
Offline Engineer
Re: Blazer fuel tank
« Reply #1 on: January 29, 2013, 09:43:29 pm »
I used a tank out of a '75. It was a 20 gallon.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #2 on: January 30, 2013, 01:17:58 pm »
1973-86 if you don't need a fuel pump, 87-91 if you do.
Offline Low87
« Reply #3 on: January 31, 2013, 09:27:04 am »
I'm pretty sure up to 31 gal will fit.  I think somewhere on Chris's site the dimensions are posted.
Offline Trimmy
« Reply #4 on: February 03, 2013, 07:54:28 am »
I plan on running an external fuel pump for my tbi swap.
Offline Rich84
« Reply #5 on: February 03, 2013, 03:25:13 pm »
Get the fuel injected tank...only way to guarantee you won't have fuel starvation problems when your tank is under a quarter full.. You may still be able to use an exterior pump also.
« Reply #6 on: February 04, 2013, 01:11:00 pm »
Either tank from a a Blazer 25-31g will fit in the rear of the frame.  There are pics of my current truck with it, along with my write-up here http://www.captkaoscustoms.com/blazertank.html
I wouldn't run and external pump, there is a reason factory uses them in the tank...
Offline Low87
« Reply #7 on: February 06, 2013, 01:16:28 pm »
^this times 10
Ask me how I know.  Save yourself a ton of headache and use the factory style pump/sender assembly.
