Author Topic: one ton swap..  (Read 4410 times)
Offline winky
one ton swap..
« on: March 19, 2013, 07:47:47 pm »
I got s decent deal on a 15 buff rearend and Dana 60 front . I am looking for advise and what not on how the best way to go about swapping them into my 1/2 ton truck. D 60 is direct bolt up right? 14bff I'll have to move the spring pads
. As far as breaks go I'm changing to hydro boost anyThing need to be changed besides pump and master cylinder? Thanks in advance
Offline winky
Re: one ton swap..
« Reply #1 on: March 19, 2013, 07:49:44 pm »
On my phone sorry for bad grammar and errors I'll fix it in the morning
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: one ton swap..
« Reply #2 on: March 19, 2013, 09:18:49 pm »
How much lift? Long or short box? Welding on new spring perches is a great time to get your pinion angle correct. If you do have a lift it may come with pinion angle wedges this will be a good time to ditch them as over time they can split .
Offline winky
Re: one ton swap..
« Reply #3 on: March 19, 2013, 10:04:21 pm »
Swb and 6" lift, had already planned on taking advantage of using new perch. Locations. And using them. To fix pinion angle. Thanks for the reply, any other ideas?
Offline Engineer
Re: one ton swap..
« Reply #4 on: March 19, 2013, 10:09:38 pm »
If you can find a 14-bolt out of a 3/4 ton it will have the spring perches, and shock brackets right where you need them. Otherwise the 3/4 ton 14-bolt FF is the same as a 1-ton 14-bolt.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline winky
Re: one ton swap..
« Reply #5 on: March 20, 2013, 07:03:54 am »
That's what I've been told these came as a set for a good deal so there what I have to work with lol
Offline ehjorten
Re: one ton swap..
« Reply #6 on: March 20, 2013, 10:03:22 am »
For the Hydroboost...I replaced my leaky one with a new rebuilt one and at the same time I put a more modern composite M/C on it (Aluminum master with plastic, see-through reservoir).  Bolted-up just right with all of the same port sizes and everything!  I'll have to research a bit to remember what the application was that I picked it off of, but it was a newer Chevy truck.
-Erik-
Offline winky
Re: one ton swap..
« Reply #7 on: March 20, 2013, 04:45:39 pm »
Awesome thanks, guy said I could rob all the brake stuff off a truck he has for $75
