Author Topic: power steering bracket  (Read 9410 times)
Offline popsthebuilder
« on: March 20, 2013, 05:27:59 pm »
The bracket that allows you to tension down the belt and lock pump in place is broken. I have no clue were to get one. Looked in the store here. Would the water pump on a 350 ci  in a 73 c20 be considered a lwp (long water pump)?
Offline gildardo01
Re: power steering bracket
« Reply #1 on: March 20, 2013, 06:03:43 pm »
yeah its a long water pump... short water pumps are for corvettes i think... and how about the junk yard, you might be able to find a used one... btw your talking about the bracket that goes on the manifold right?
« Reply #2 on: March 20, 2013, 07:36:36 pm »
Yards crush everything that old around here. Here is a pic I think.
« Reply #3 on: March 20, 2013, 08:35:41 pm »
So did you break it? Where's the rest of the bracket? You can weld yours back together, go to the boneyard or get an aftermarket one.
http://www.ebay.com/itm/SBC-CHEVY-327-350-383-POLISHED-ALUMINUM-POWER-STEERING-BRACKET-9105-P-/330763333744?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0307f070&vxp=mtr
Offline gildardo01
« Reply #4 on: March 20, 2013, 10:16:06 pm »
35 dollars for the aluminum bracket seems to me like a good deal... or if you have access to a welder just weld a piece of metal from where the other broke off.. if you weld it it´ll be free and thats the best part...
« Reply #5 on: March 20, 2013, 10:56:05 pm »
It was broke when I bought the truck so I don' t have the missing piece. I also checked local yards, and parts stores. Trying to keep truck original, or close so a brushed aluminum, or chromed bracket isn' t really going to be a good fit either.
Offline SigFTW
« Reply #6 on: March 26, 2013, 11:44:50 am »
I went thru the same thing however it was the fixed pivot bracket. I just installed a universal power steering pump bracket. Was a bit more than I wanted to spend but did the job with a minor mod to one busing.
« Last Edit: March 26, 2013, 11:47:03 am by SigFTW »
