Author Topic: loose steering  (Read 5483 times)
Offline old chevy man
loose steering
« on: March 23, 2013, 08:43:42 pm »
Hi guys, Ive got a 1973 k10 chevy truck. Not sure of the mileage, guessing around 150,000 miles. Everything up front is all original to my Knowledge. Its got a Dana 44 up front with a 3 inch suspension lift and 33x12.50 tires on it. Good running truck I have had it for 3 or 4 years and have noticed that the steering has got some play in it. Its loose. Was wondering what I could do or check and look at to figure out why it's like this. I am guessing my steering box has got some slop in it but how can I tell for sure? Thanks, any input on things to check are well appreciated.
Re: loose steering
« Reply #1 on: March 24, 2013, 01:08:18 pm »
If your tie rod ends, and drag link are tight. Turn the wheel back and forth, if the tires don't respond almost instantly then the steering box would be the likely culprit. Watch the steering column under the hood / through the wheel well while the wheel is being turned, the steering arm should move at the same rate no hesitation.
Offline scorpion
loose steering
« Reply #2 on: April 11, 2013, 08:11:48 am »
Saginaw steering boxes are adjustable.  Google - adjusting a saginaw steering box.  It's fairly easy.  I would also, as noted, checkout your steering components.  A little slop in a few steering parts can cause a very sloppy steering wheel.
Offline 79gmc15
Re: loose steering
« Reply #3 on: April 11, 2013, 11:40:50 am »
Your frame could also be cracked which results in flexing and a loose steering wheel.
Re: loose steering
« Reply #4 on: April 12, 2013, 08:04:33 pm »
Search the forum for "dry park check"
