Author Topic: Serpintine belt  (Read 2841 times)
Offline Cruz.cab
Serpintine belt
« on: March 28, 2013, 05:33:08 pm »
I'm thinking about changing from vbelts to the serpintine belt but I'm confused on what accs holes I need or is there a setup that I wouldn't need to use these holes I only have one hole in the pass head
Offline Twin_Turbo
Re: Serpintine belt
« Reply #1 on: March 28, 2013, 06:08:01 pm »
For an F body setup you need this hole on the pass head:
behind the tensioner, it's the lower hole.
same spot as on the drivers side where the stud is (under the hose end in the pic)
Offline Cruz.cab
Re: Serpintine belt
« Reply #2 on: March 28, 2013, 08:31:03 pm »
Um I'm still confused so I have a hole for the alternator but am I supposed to have one or 3on the passenger side
Offline Twin_Turbo
Re: Serpintine belt
« Reply #3 on: March 28, 2013, 08:34:38 pm »
cast iron heads? There are actually  several different patterns and not all heads have all the holes. what exactly do you have?
Offline Cruz.cab
Re: Serpintine belt
« Reply #4 on: March 28, 2013, 08:50:04 pm »
882 is the casting number
