Author Topic: Slack in throttle cable  (Read 3135 times)
Offline Fairlane514
« on: April 04, 2013, 05:49:46 pm »
I have an 84 with original Qjet and I assume original throttle cable. The gas pedal is pretty close to the floor and I can lift it up and feel the cable tighten. At the carburetor I can push down on the cable between the intake mounted bracket and the carb linkage and feel the cable tighten. I can push the cable down at the carb probably a 1/2 inch.
Do the cables stretch over the years? Seems like it should have very little play in order to get WOT.
I don't know if routing of the cable makes a big difference or not. Mine comes out of the firewall and loops down and then back up to the intake bracket.
« Last Edit: April 04, 2013, 06:06:54 pm by Fairlane514 »
Re: Slack in throttle cable
« Reply #1 on: April 04, 2013, 07:25:53 pm »
The cables don't really stretch so much as the pedal arm under the dash bends with normal use, so that you gradually lose throttle opening.  Have a helper watch for WOT and rebend the arm.  You should have some slack in the cable so you're assured of complete throttle closing.
Offline Fairlane514
« Reply #2 on: April 04, 2013, 09:00:22 pm »
Ok, thanks.......I will bend the arm back......the bottom of the pedal closest to the floor, just about touches the floor
Offline 86silver
« Reply #3 on: April 08, 2013, 10:31:40 am »
Good to know thanks.  When adjusting my TV cable the pedal to the floor won't open the carb to WOT, so this will help!
