The Lows (Lowering/Drops)
lowering options
Topic: lowering options (Read 11893 times)
launchpad
lowering options
April 12, 2013, 12:28:44 pm »
Any ideas on the most affordable way to get a 2 1/2 and 4 in the rear drop on an 82, 6.2, 1/2, 2-wheel drive Chevy? Thanks
Canadian 4X4
Re: lowering options
April 12, 2013, 12:35:31 pm »
cheapest way is cut one loop off the front springs and buy a shackle and hanger kit for the rear. or go 3/5 buy or make a flip kit for the rear and buy a 3" drop spindle. if you ever plan to go lower in the future go with the flip kit and spindle.
launchpad
April 12, 2013, 01:15:27 pm »
You would need to replace the shocks as well then?
Canadian 4X4
April 13, 2013, 01:07:38 pm »
if you go with spindles you dont have to change the front. in the back you will need shorter shocks no matter what
79brent
Shake and Bake!
May 10, 2013, 11:08:58 am »
They make 2", 2 1/2" and 3" drop spindles. As canadian said, the best way to do the back would be the shackle and hanger kit. Doesn't cost much at all except the spindles. Lots of companies make the kits that come with the spindles, shackles and hangers. This will also be the best way to go because you dont sacrifice ride quality or load capability.
1979 Chevy C10 Silverado package. 350/350
"Lifes a garden DIG it"
79brent
Shake and Bake!
May 10, 2013, 11:10:29 am »
Keep in mind also, the 3" drop spindles will require some fab with a 15" or 16" wheel. I believe you have to trim a little bit off the a-arms or the wheels will rub.
Tx Firefighter
lowering options
May 11, 2013, 10:12:01 am »
It depends on the wheels as to whether you'll need to trim the arms with a 3 inch spindle. I run stock wheels (hubcap style skinny wheels) with 3 inch DJM spindles and they clear by a mile. Rally wheels will need trimming though.
79brent
Shake and Bake!
May 11, 2013, 10:53:46 am »
Are you talking about the 15x6 steel wheels?
Tx Firefighter
lowering options
May 11, 2013, 05:12:42 pm »
Yep. The stock skinny steel hubcap wheels. Don't judge the truck too harsh. It's a 100 percent new underneath with the best parts I could buy. I'm a geek for top quality suspension, brakes, and drivetrain parts and am completely allergic to Chinese cheap parts. I just haven't spent a minute or a dollar on appearance yet.
May 11, 2013, 07:51:17 pm »
you always need a good base to start on
79brent
Shake and Bake!
May 11, 2013, 08:59:24 pm »
Some nice looking wheels
. Im starting to be allergic to chinese parts to lol
May 20, 2013, 12:56:49 pm »
If you get shock extender brackets for the rear you don't need different shocks.
greasemonkey54
May 21, 2013, 06:25:44 pm »
Hey 79brent, who makes 2 inch spindles, I always find 2.5 or 3 only.
79brent
Shake and Bake!
May 22, 2013, 04:10:19 pm »
P/N-CP30106-4 Classic Performance. Type in that number on
www.summitracing.com
greasemonkey54
May 23, 2013, 11:19:54 am »
it says they only work with the 1.25 inch rotors. Thanks tho
lowering options
