Author Topic: My ebrake cable isn't putting tension on the pedal to pull it back  (Read 4050 times)
Offline cwest
Does that sound like a stretched cable or a bum spring in the drum itself?  I'm just looking for some general thoughts before I go tearing into something I don't need to.  Thanks for any input
86' Chevy K20
350/SM465/np208
08' Silverado 1500 4X4 WT
Offline 79gmc15
Re: My ebrake cable isn't putting tension on the pedal to pull it back
« Reply #1 on: April 12, 2013, 02:27:43 pm »
Make sure you adjust your rear brakes, if that doesn't work then tighten the e brake bolt under the drivers seat by the frame.
« Reply #2 on: April 12, 2013, 07:31:57 pm »
You need to pull the drums, clean and inspect. Ensure the shoes are fully seated on the anchor pin and adjust the shoes. Don't mess with the cable until you do so.
