Author Topic: truck cough  (Read 6290 times)
Offline flips87c30
truck cough
« on: April 12, 2013, 08:35:15 pm »
My truck has recently developed a cough/stutter it only seems to happen at mid throttle it wont happen once I am up to speed, or when I give it more to get up a hill. But going from a dead stop it coughs like crazy. It also runs just fine in park I can rev it up no problems. Im thinking I should start looking at the distributor cap and rotor. I just replaced them mabey I screwed something up? Any suggestions? Thanks in advance.
87 v30 duelly dump truck 454, th400, np205, dana 60/14 bolt, warn hubs, gmt800 mirrors and LEDs all around the bed.
Offline Mule man
Re: truck cough
« Reply #1 on: April 12, 2013, 10:09:39 pm »
I'm almost sure that you have a vacuum leak.  Probably a cracked rubber line somewhere.
Offline flips87c30
Re: truck cough
« Reply #2 on: April 14, 2013, 12:22:04 pm »
Been working on the truck all morning still cant figure this out. I cant find any leaking vacuum lines. It runs fine for a mile or two then starts acting up again.It was running fine, before I replaced the following, right side exhuast manifold, dist cap and rotor, map sensor, thermostat, and the preheater hose. this cough has me stumped its almost like a really quiet backfire. Could it be my pick up coil? At this point im just guessing.
Re: truck cough
« Reply #3 on: April 14, 2013, 01:22:03 pm »
Could you have accidentally crack the ceramic on a spark plug or damage a spark plug wire?
Offline flips87c30
Re: truck cough
« Reply #4 on: April 14, 2013, 02:50:09 pm »
yes. thanks zieg. I dont even know what to say for myself.
Re: truck cough
« Reply #5 on: April 14, 2013, 03:49:11 pm »
Try Robitussin  ;D
So is it skipping or hesitating?
Re: truck cough
« Reply #6 on: April 14, 2013, 04:03:35 pm »
My initial thought was "does anyone have a Ricola?"
Re: truck cough
« Reply #7 on: April 14, 2013, 04:08:51 pm »
RRRRIIIICOLAAA!!!!
Offline flips87c30
Re: truck cough
« Reply #8 on: April 14, 2013, 09:26:43 pm »
Try Robitussin  ;D
Obviously tried Robitussin first thing but it fouled my injectors, the vicks vapor rub on the air filter proved equally useless.  In all seriousness I guess Its skipping. But I think I found my problem when I looked closely at the plug wires. one was partially melted. time for a new set. any suggestions, What brand do you guys use?
Re: truck cough
« Reply #9 on: April 15, 2013, 01:20:50 pm »
I run off the shelf stuff for my driver..  Accel MSD or Taylor for my non-stock stuff.
Re: truck cough
« Reply #10 on: April 16, 2013, 08:40:17 pm »
Always run a good quality set of ignition cables don't get the cheap ones.
