Author Topic: AC and Heater cover/take out  (Read 11143 times)
Offline bowdown916
« on: April 13, 2013, 11:38:12 pm »
Sup guys, not sure if this its the rigt place to post my question,but here i go.
I was thinking on taking out all the AC stuff, i never use it and dont think i ever will, so ill need something to cover the firewall, also was thinking on taking out the heater part to inside the cab,just trying to clean the truck has much i can..
anyone done this before?
Offline danno_73c10
Re: AC and Heater cover/take out
« Reply #1 on: April 15, 2013, 09:52:14 pm »
I have a friend that did this to his truck.  In my opinion it looks weird.  The Ac stuff I can see removing if not used...but the blower motor housing I'm not sure about.  But I guess it depends on what you do with the empty space or how you cover it.  His just has a piece of small gauge steel bolted over the hole.
Offline bowdown916
« Reply #2 on: April 16, 2013, 12:04:52 am »
He made it?
Offline danno_73c10
« Reply #3 on: April 16, 2013, 12:43:47 am »
Yes.  Its 12g steel.  Real thin.  Cut it and bolted it.
Offline bowdown916
« Reply #4 on: April 16, 2013, 01:04:18 am »
By any chance you have any pics ?
Offline danno_73c10
« Reply #5 on: April 16, 2013, 09:00:28 am »
No.   I don't have any pics.  He didn't do the greatest job on it anyway.  Lol.
Offline bowdown916
« Reply #6 on: April 16, 2013, 09:03:14 am »
Offline hoyle83
« Reply #7 on: April 16, 2013, 10:04:57 am »
I got rid of the A/C but kept heat, bent, welded, riveted this eye sore under my hood...
Mitch Hoyle
KCCO
"Work Hard To Play Hard....Or To Fix Your Toys....And Then Play Hard!"
« Reply #8 on: April 16, 2013, 11:55:35 am »
think theres a post about this on here. ill try to find it but search for it
Offline bowdown916
« Reply #9 on: April 16, 2013, 12:14:57 pm »
Ok thanks..
Offline bowdown916
« Reply #11 on: April 16, 2013, 02:03:53 pm »
Thanks !!
Offline greenXpress
« Reply #12 on: April 23, 2013, 08:23:25 pm »
I like this "eye sore" idea.  Did you use any part of the original a/c box, or just fab a total new box?
I need to keep the heater.  Drive this truck just about every day.
Offline hoyle83
« Reply #13 on: April 24, 2013, 08:12:53 am »
I literally used channel locks, chisels, a knife and a die grinder to cut back the A/C and heater box apart (because its all gummed onto the firewall) and removed the condensor but only cut the plastic/fiberglass outer shell back close enough to the blower housing that i could mould the eyesore to it, used some rtv as a sealer and riveted it right to the firewall!
Mitch Hoyle
KCCO
