Author Topic: New exhaust question X- vs H-pipe  (Read 4680 times)
Offline Dirka
« on: April 26, 2013, 03:28:45 pm »
Hey all,
Putting new exhaust this upcoming monday on the ole 77 K10 305. Nothing special for mods except a mild cam and set of flowtech afterburner headers and a edelbrock 600cfm 4bbl carb.
I'm going with my personal preference of magnaflow mufflers, but curious on what peoples opinions and thoughts are on the X or H piping and where to put the X or H in the system?
Thanks.
I should also mention I plan on doing turn downs instead of going out the sides or all the way out back. (if that matters)
« Last Edit: April 26, 2013, 03:30:41 pm by Dirka »
Re: New exhaust question X- vs H-pipe
« Reply #1 on: April 26, 2013, 04:27:43 pm »
you want back pressure of some sort. "x" need some room to cross in and out, "H" dont need much room at all. x will give you  more back pressure since it forces the gas to mix. h will do the job but not as much as the x will since it its not forced but its better than nothing
« Reply #2 on: April 27, 2013, 01:32:13 pm »
H pipes tend to lend performance gains in low RPM range while X pipes help high rpm gains. I prefer an H pipe to avoid unecessary obstructions. Either is better than neither
Quote
Curious why you want to do this?
Offline Engineer
« Reply #3 on: April 27, 2013, 02:49:00 pm »
The closer you can get the cross over pipe to the headers the better it will work.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline Dirka
« Reply #4 on: May 01, 2013, 07:17:54 pm »
Vile, just something I want to do and see how it sounds.
