Members Rides
83 LWB Under Construction
Topic: 83 LWB Under Construction (Read 10640 times)
scorn86
June 05, 2013, 01:26:33 am »
Hey guys,
I picked up my truck earlier today and cant wait to finish fixing it.
The truck has a newer fuel injected 305 in it for now, came to me with a bhg.
Overall it isn't too bad and i'm quite happy with it and excited.
This is my first chevy truck and I have loved this body style since the first time I saw one.
Right now I only have one pic of the truck but here she is.
Last Edit: June 05, 2013, 01:45:17 am by scorn86
Re: 83 LWB Under Construction
June 05, 2013, 01:38:00 am »
use the img code when posting so it pops up on here [¡mg]https://imageshack.us/scaled/large/694/20130604143306.jpg[/img]
scorn86
June 05, 2013, 01:44:13 am »
Thanks
June 05, 2013, 03:19:28 am »
no problem
and welcome from maryland
Last Edit: June 05, 2013, 03:39:15 am by Irish_Alley
blazing816
A Truck Is Built, Not Bought
June 05, 2013, 08:33:05 am »
Welcome from Michigan.
74 C-10 Shorty
June 05, 2013, 08:59:15 am »
Welcome from California, nice ride.
scorn86
June 05, 2013, 02:07:02 pm »
Thanks everybody, I'm from texas here.
After I finish moving it will be all truck time.
Right now the main plan is get it running and legal
Then fix the few small cosmetic issues (RH inner and outer fender are shot and bed has a bad spot).
I will post more pics tomorrow after the moving is done.
Jason S
June 05, 2013, 08:03:36 pm »
Howdy from Oklahoma.
scorn86
June 19, 2013, 10:52:16 am »
Hey Guys,
So far I have then engine back together and now i'm trying to figure out the confusing wiring.
I was not the one who pulled the wiring, also a smog and ac system has been removed.
Needless to say there is a ton of extra wires and this harness is in terrible shape to start with.
With a little luck I will get it all figured out.
Can anyone tell me where I would find the block id code?
This is not the original engine all I know is its a tbi 305.
June 19, 2013, 04:59:47 pm »
The engine ID is on the back of the block where the bell housing bolts up.
scorn86
June 19, 2013, 06:44:47 pm »
I couldn't get back there enough to see a code anywhere. Can I use the one on the pad above the water pump?
It reads k0304fbm and below that is chs152435. Anyone know a site to decode these?
Last Edit: June 19, 2013, 08:21:56 pm by scorn86
scorn86
June 19, 2013, 06:45:09 pm »
Thanks for all the help btw!
June 19, 2013, 08:23:56 pm »
K030FBM isn't enough numbers.
The Suffix is broken down by Plant = first letter, month = next 2 numbers, day = next 2 numbers, last 2 or 3 is Engine suffix code.
K = St Catherines, Ontario Plant
30 = 30th
FBM = 1987 350 L05 TBI motor..
The other number is the partial VIN from the source truck.
scorn86
June 19, 2013, 10:17:45 pm »
thanks kaos, i've found some contradicting things on my truck.
It seems to be a 350 block with 305 heads and a 350 tbi intake all wrapped up in a 83 body.
I was originally told it was a 305 so i won't complain lol.
I'm going to pick up a set of 350 heads and a holley 4 barrel intake tomorrow.
That should fix my wiring nightmare i have going on.
Thanks again for the help.
scorn86
June 20, 2013, 11:30:16 pm »
Well I ended up with an edelbrock performer rpm intake, a set of 462624 casting heads, and an hei dizzy.
Now all I need is to get a carb and it will be good to go.
Members Rides
