Author Topic: body mount kits  (Read 7363 times)
Offline winky
body mount kits
« on: June 08, 2013, 07:47:33 pm »
Im swapping everything off my 77 frame onto an 84 frame. I can't find where I can buy the metal parts of the body mounts only rubber... anyone know where I could find a complete kit that would include the metal washers as well?
Offline 74 C-10 Shorty
Re: body mount kits
« Reply #1 on: June 08, 2013, 08:05:08 pm »
Offline winky
Re: body mount kits
« Reply #2 on: June 08, 2013, 08:14:32 pm »
Still doesn't look like it has all the metal bowl like washers. I'll print not of a parts diagram at work Monday and make sure I'm not over thinking. That ks
Re: body mount kits
« Reply #3 on: June 11, 2013, 04:07:46 pm »
You need to keep the cups from the 81-up frames, they aren't supplied aftermarket.
Offline winky
Re: body mount kits
« Reply #4 on: June 16, 2013, 11:54:31 pm »
^^^ crap... don't have them.. just ordered a kit from a company the reassured me that it would include everything I needed.. ( told them I had a bare frame and needed everything that was required to bolt the body on) guess I'll find out this week. Anyways I have another question... there was one kit for 81-83 and another for 84-87... anyone know why? Different style washed used? Of something that's a bigger deal?
Re: body mount kits
« Reply #5 on: June 17, 2013, 10:41:26 am »
The body mounts split in 73-80 and 81-87(91), They are different for each application though: Pickup, Blazer, Suburban.
Be prepared to find the cups.
Offline winky
Re: body mount kits
« Reply #6 on: June 17, 2013, 09:12:48 pm »
There is an 81+ truck in a field on my way home from work... goes I'll grab the torches from the shop Friday and go borrow some cups ;) lol jk  and crap.. well I have one
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: body mount kits
« Reply #7 on: June 18, 2013, 08:27:32 am »
1981 and up washers are like gold up here in NY cause there usually all rusted out. At one time you could get them through the dealer at like 8 bucks a pop.
Offline winky
Re: body mount kits
« Reply #8 on: July 14, 2013, 08:35:53 pm »
Found a complete kit with everything including bolts for $175 thanks every one
Offline DustyRusty
Re: body mount kits
« Reply #9 on: July 17, 2013, 07:17:38 pm »
Winky:  This seems to be a fairly common problem.  Could you provide a link to the source of the kit you obtained?  I'm sure others would like to take advantage of your research.
Thanks.
Customized by rust.
