Author Topic: Power window switch wiring - Where do I find some?!?!?  (Read 10644 times)
Offline nlauffer
« on: July 08, 2013, 05:12:34 pm »
I am taking apart the doors to rebuild them (window motors, switches, door lock actuators, vent windows, weatherstripping, hinges).  The problem is that I lost the backing piece to my driver's side window switch wiring plug.  It is the one with 6 wires and it is flat and plugs on to the window switch.  Where can I find good ones?  I can't find any in salvage pickups around here.
Were they the same in some GM cars?  My wires are falling out of it and has caused some sparks.  Unfortunately, I am still driving this thing while working on it.  Sure makes it difficult to get much done.
Re: Power window switch wiring - Where do I find some?!?!?
« Reply #1 on: July 08, 2013, 07:16:20 pm »
ACDelco PT188 or PT546 available through your local ACDelco retailer.
Offline nlauffer
« Reply #2 on: July 08, 2013, 10:00:34 pm »
Awesome thanks
Offline nlauffer
« Reply #3 on: July 08, 2013, 10:14:28 pm »
Is the shape the only difference. Mine is an 83 GMC
Offline nlauffer
« Reply #4 on: July 08, 2013, 10:17:19 pm »
Oh yeah. Does anyone know why there is one post on the switch that is so much longer and sticks through the plug
« Reply #5 on: July 09, 2013, 12:33:53 am »
I believe the two connectors pictured are interchangeable, but the PT546 (white connector) may be slightly thinner(?).
The long post is for a retainer that binds the connector to the switch.  In my experience, the retainer is unnecessary since terminal tension is sufficient to retain the connector.
Offline nlauffer
« Reply #6 on: July 09, 2013, 12:44:24 am »
Thanks. I took my old one out (actually fell off in my hand) and it is the white one.
Do you have the numbers for the lock switch plug and passenger window switch plug also?  I have looked for these parts by application and had not found the ac delco stuff, but knowing the part number they are easily found. Thanks again.
« Reply #7 on: July 09, 2013, 08:31:32 am »
Door Lock Switch Connector:
PT294 in AC Delco 3-Way Connector Buyers Guide
Right Window Switch Connectors:
PT187, PT254, PT599, PT602 in AC Delco 5-Way Connector Buyers Guide
Offline Displaced_Txn
« Reply #8 on: July 09, 2013, 01:07:51 pm »
classic industries, but parts stores should be able to get it quickly also.  I know oreillys does nightly truck shipments to their stores  if one is close to you.
« Last Edit: July 09, 2013, 02:08:31 pm by Captkaos »
